Tranny and tranfer case rumor
Does anyone know if our evo tranfercase and tranny is weak?
Just wondering cause i was told by an x evo owner he blew the tranny twice...
well let me know thanx
our friend lol.... and to somewhat answer the question... the drivetrain in the 03 seemed to be a little weaker, i have an 06 now and its holding up just fine
it all depends on how it was taken care of. usually the 03 and 04 8's were weaker in the Transfer case due to the front diff being open. eventually, after many a hard launches, it begins to whine. gets hella annoying.
mine was doing it, so i sent mine to shep to get built. i think i would have done it anyway, as its usually a weak point on awd cars, especially if you frequent the drag strip. i had my tranny built too, but that was holding up perfectly fine before i had it built.
check out the search feature, as you'll find tons and tons on this topic. laater
_Greg
_Greg
Originally Posted by TTOPPOUZI
Transcases from evo viii to xi are not weak and can not be changed into racing ones.This is the opposite case for evo iv to evo vi.I know because i have an evo vi 1000hp and i do not know what to do with the transfer case,because is the cars only fault,i tried to find a company to get me a custom racing one like they do for evos vii-ix but was pointless.
Why do the axles need to be changed when changing from AYC to a conventional diff? Since the AYC pumpkin is larger the axles are shorter. You wil also save weight by changing to an RS setup because you will be able to remove the AYC pump assembly.
Dave2
Feb 3, 2013 08:09 AM
vietdragontekx
10
Oct 7, 2010 03:10 PM
