early rev limit/fuel cut off at 5600rpms?!
Old Dec 9, 2006 | 08:59 PM
MrEvoVIII's Avatar
early rev limit/fuel cut off at 5800rpms?!
I don't know what the heck is goin on but my 05 MR is reaching rpm cut off at sporatic rpms. The 1st time it happened it was at 5800, the second time it happened it was around 6300.. where the check engine light came on. I reset the ecu, the CEL went away but just did it again today at 5800 again.
I'm stumped.. I've never touched the ecu and it just started happening out of no where.. any ideas guys? Thanks in advance..!
Mods: dp, test-pipe, w/ catback
Old Dec 9, 2006 | 09:45 PM
PVD04's Avatar
If you are not tuned then you are probably hitting fuel cut. With the cooler air you could be hitting higher load cells than you were in warmer temperatures. You need to get the car tuned.
Old Dec 9, 2006 | 09:48 PM
Ultimate CC's Avatar
fuel cut, get tuned, or buy a tactrix cable with either you tuning it or a eflash from a tuner like jestr...
Old Dec 10, 2006 | 02:18 AM
MrEvoVIII's Avatar
Thanks for the replies guys! Now that I think of it, it did start happening when the weather got colder out. Do you think the weather has that much of an impact..?!
Old Dec 10, 2006 | 02:44 AM
o.e.boost's Avatar
yep...im getting too...im yet to get it tuned...but i just got the cable and have been messing with my limiters...and it seemed to go away when i raised the boost limits!!!
Old Dec 10, 2006 | 04:26 AM
evo150's Avatar
yes it does make that big of a impact. get a flash. i would also get a boost controller. the cooler temps and tbe are causing you to boost higher and hit fuel cut
Old Dec 10, 2006 | 12:51 PM
thaigleshmk's Avatar
tune tune tune....
Old Mar 6, 2007 | 03:39 PM
MrEvoVIII's Avatar
thanks for all the replies! Now the big question is that since weather is such a big factor, if I took the car to get tuned in the winter will it run differently when summer hits or will the ecu "learn" with the different weather/temp conditions..? Thanks for any input!!
Old Mar 6, 2007 | 04:52 PM
TVA's Avatar
TVA
If you tune it in the winter the worst that will happen is you'll be rich in the summer. A good tuner should be able to compensate for that though. Colder air is more dense, obviously. With more dense air you are going to want more fuel to make use of the combusion, therefore making more power. This puts you in higher load cells in the ECU. Any tuner worth his salt will be able to tune your high load cells for an AF ratio that is comfortable for you and may tune your slightly lower load cells a bit more lean so you're not pig rich during the summer.
Old Mar 6, 2007 | 05:02 PM
neweraevo8's Avatar
I have a 2005 Evo with dp,catback,testpipe,o2 housing,headers,intake,upper ic pipe,clutch, flywheel, and blow off valve and i dont have it tuned and it doesnt get fuel cut off. So maybe its not ecu issues.
Old Mar 6, 2007 | 06:59 PM
Warrtalon's Avatar
It is definitely fuel cut, neweraevo8. Why you aren't hitting it despite foolishly running your car untuned with all those mods is a mystery, but for this guy, it's definitely fuel cut. An exhaust without boost control and a tune really is senseless - I'm not sure why people still do this after countless threads just like this.
Darewood
241
Jun 25, 2016 10:33 PM
Cornerstrike
Jan 22, 2009 05:42 PM
tinkolby_25
28
Sep 18, 2008 11:47 AM
Sgt Blamo
102
Dec 17, 2007 07:48 PM
urbanknight
Oct 18, 2003 08:52 PM
