over boosting with ported manifold
Old Dec 9, 2006 | 11:43 PM
idriveanevo's Avatar
so i just installed my buschur ported manifold and now in cold weather i cant adjust my peak boost below 21psi, i have a forge wga and a greddy profec ebc(old one). i can adjust it to hit about 15 at 4000rpm but by 6000 im already at 21 and hit fuel cut or whatver cut... before the manifold i could hit 19 with no movement at all but have to constanty adjust due to temp. any help, and why does my boost taper up???
Old Dec 10, 2006 | 03:27 AM
sparky's Avatar
You might try loosening the turnbuckle on your Forge WGA's threaded rod...about 2 full 360* turns....that is, lengthening the rod, thus lowering the WG preload setpoint. Another possibility might be that you need to port(enlarge) the turbine housing's WG bypass port, especially if you're still running a 9.8 HS.
Old Dec 10, 2006 | 02:40 PM
im running the 10.5 hotside
Nevolution
17
Feb 13, 2013 07:40 AM
dzraduzit
13
Dec 30, 2008 09:29 PM
prostcj
Jul 27, 2008 04:36 PM
EVIL_EVO_VIII
20
Mar 10, 2006 09:50 PM
05evoGSR
Oct 1, 2005 03:36 PM
