oil leak...please help
Old Dec 15, 2006 | 03:52 PM
steevo's Avatar
Been searching all day for this answer, and this looks like it. From user:
Phenix fya
Already replaced mine, wasn't hard to do.
Optional:remove Intake pipe.
Remove BOV
Remove top section of IC pipe
Remove Top Radiator Hose
Remove Turbo Coolant hose
Replace
And reverse
45mins tops and doesn't require mechanical skills
I have never done this much, but it seems very do-able. All I need is the hose, but don't want to get it from a Mitsu dealer. Should a regular coolant hose the same size be o.k. I guess? Thanks for all the help, I gotta get it running! Oh, and what should I do about all the coolant sprayed everywhere in my engine bay?
Old Dec 15, 2006 | 04:25 PM
barneyb's Avatar
Well, first of all, you can't be driving with antifreeze leaking. This engine (aluminum head on iron block) will warp the head every time. If you think you have problems now, a blown head gasket will make you quickly forget them. So, park the car and make other arrangements until you get it fixed.
What's wrong with going to the dealer. They have the parts book and all the parts fit. Yeah, sometimes they can be pricey, but we are talking about a hose here. What is nice about the better hoses is the bends are formed in them when made. Another thing about the dealer some people don't know is that they get parts overnight - they always say about a week. So, say, "No, I want it tomorrow."
But, for one hose, stock coolant hose, as long as it has the same inside and outside diameter should be fine. From the look of the clamp, I'd suggest the hose on there now is not OEM. So make sure to buy hose that fits snugly.
As for the spilled antifreeze, hose it off with a garden hose but don't spray with pressure.
Old Dec 15, 2006 | 04:37 PM
steevo's Avatar
I only drove about 200 yards afterwards, it is parked now. It's sitting all alone in a bad parking lot overnight. The problem I have going to the dealer or anywhere right now is expense. Tow plus labor is just too much. Plus, I dont want Mitsu to work on it , or see my mbc and cams. I'm going to try to fix it, or atleast remove the existing hose first thing tomorrow. Thanks for the advise. The garden hose will come next...
Forgot to mention: I have to borrow tools. Other than a good socket set, what else will I need to do this job?
Old Dec 15, 2006 | 06:46 PM
barneyb's Avatar
If you don't drain the cooling system first the level of antifreeze is going to drain to the level of the removed hose. So, figure on a gallon of antifreeze and a gallon of distilled water mixed 50:50. By the way, do this mixing outside of the radiator.
Old Dec 16, 2006 | 05:40 AM
steevo's Avatar
I don't understand what you mean by "mixing outside of the radiator". I have already bought 2 gallons of pre-mixed coolant. What do I need to do different if I don't drain the cooling system? I am going to start in about an hour.....any more suggestions on the job or tools? Thanks....I need it.
Apr 24, 2014 07:57 AM
diponyou
11
Jul 13, 2013 09:04 PM
rrkpitt15
Jun 10, 2010 04:07 PM
94AWDcoupe
18
Jan 27, 2006 02:22 PM
ArchieBabes
17
Oct 6, 2004 10:11 AM
