Flooded the Evo....Please help.
Old Jan 5, 2007 | 10:38 AM
joeymia's Avatar
i cleaned my engine bay once and this happened. Drove around for about 30 minutes and it went away. Something must of just got wet...
Old Jan 5, 2007 | 10:47 AM
BoostWhore's Avatar
sounds like something electrical
Old Jan 5, 2007 | 10:52 AM
SilverNine's Avatar
same thing happened to my friends gti, he just took alot of crap apart and cleaned it and replaced sum parts and the car is fine... i'll find out what was the exact problem with his car later....
Old Jan 5, 2007 | 11:03 AM
4Gsixty3's Avatar
thank god at least the engine still runs! it just might be some electrical parts needs to be replace
Old Jan 5, 2007 | 11:32 AM
xmaciek82x's Avatar
Yea, alot of the guys with GTi sget cold air intakes, which sit VERY low by the bottom of the front bumper. I know few guys that hydrolocked there cars, but the evo on the other hand, I don't understand how its possilbe. You would have to go throw a "puddle" that is over 2 feet deep i would imagine. Sounds like its electrical. Let us know what the turn out is.
Old Jan 30, 2007 | 10:34 AM
schred86's Avatar
happened to my friends r32, we flushed the oil a lot and then he brought it to j lube and flushed the motor w/ something like kerosene....i forget exactly, finally got it somewhatr back to normal, but the car never drove the same again, power wise.
cai= the devil
Old Feb 4, 2007 | 10:01 AM
JohnEB's Avatar
I would reall consider taking your mass airflow sensor out and cleaning it with a little bit of electrical cleaner.
Old Feb 7, 2007 | 11:09 AM
DanInPA's Avatar
^ 2nd that. Clean your MAF sensor carefully. It should be fine. It's not like EVO was completely submerged under the water.
By the way, insurance should cover it. As long as it was public road...
Old Feb 10, 2007 | 03:25 PM
dogfacker's Avatar
good luck, happen to me once, bascily is total
Old Feb 25, 2007 | 07:44 PM
wrcwannabe's Avatar
Unplug the MAF connector and shoot the connector and harness with electrical connector cleaner to dry it out. You can make any EVO run this badly simply by leaving the connector off. Wont rev over 2K and throws a CEL. Im guessing its wet and shorting out.
milburn
Old Feb 25, 2007 | 08:29 PM
cpoevo's Avatar
Remove all your plugs and dry out the plug wires and the connectors on the coils. Also buy the MAF sensor cleaner from CRC available at PepBoys and clean your MAF. Make sure the connector to the MAF is dry. Only reving to 2k and building boost sounds like a spark issue.
Old Feb 25, 2007 | 08:36 PM
whitersevo's Avatar
i dont get how water got into your car... unless you have an cold air intake??
Old Feb 25, 2007 | 08:38 PM
OZrallyracer's Avatar
^ same as others are saying, my buddy forgot to plug his maf sensor back in after install of an intake on his evo and the same **** happened, car wont rev past 2k and spews black smoke because it basically goes into limp mode and dumps fuel into the motor to keep bad things from happening as it isnt getting any karman readings... Check the maf sensor and maf that's where your problem lies...
Old Feb 25, 2007 | 08:40 PM
whitersevo's Avatar
and usually when you suck up water, your entire filter is soaked, but if you did suck up water i believe it would be your maf that would really take the damage, because that water has to travel quite bit, before reaching the throttle body, and engine..
Old Mar 4, 2007 | 03:20 AM
alexlewand's Avatar
hmm
ultraspeed
Dec 13, 2013 12:45 PM
NJ_evoIXgsr
Jul 18, 2013 01:34 PM
ezzey
AEM EMS
10
Jan 4, 2011 09:35 AM
LVSBB6
16
Dec 1, 2009 06:44 PM
Diavlo
34
Oct 4, 2007 05:09 AM
