Twin Pump Install Pics!!
Old Oct 26, 2007 | 02:58 PM
  #61
ETS Michael's Avatar
These are awesome!!! I run one on my personal car and Paul (ifarted2) does the same on his 1000+whp monster. We've JUST started including them in our 1200whp capable fuel systems as well
Tom
Old Oct 26, 2007 | 03:13 PM
  #62
trinydex's Avatar
Originally Posted by GTVEVO
Yes I understand that, but sock filters are still used on the pump. I wasn't aware the pump housing had yet another filter inside for the main fuel supply side, if you look at the pic I posted hopefully you can understand why I didn't see it, #12 is down on the next page so I just overlooked it and placed that in my statement above so everyone understands that it does have another filter that is needed.
Now the biggest question is where to mount this external filter in a good spot.
i had to fab a bracket that goes on a 12mm bolt right behind (lengthwise on the car) the hard fuel lines.
Old Oct 26, 2007 | 03:18 PM
  #63
GTVEVO's Avatar
Thanks dude I was able to get it taken car of without having to fab somthing up but I also used an area right behind the hard lines.
Old Apr 20, 2008 | 08:19 AM
  #64
Nesiop's Avatar
Originally Posted by FullBlown
Here is the wiring diagram for the second pump.
Is the Hobbs switch classified as a Negative trigger wire? From reading it sounds like it.
The two powers on the relay of 86 and 30 can both just go to the battery but, my question on this setup, is how come you don't mention inline fuses on these currents? Talking with one of the EvoM Guru's says a 5amp fuse should be between the low Current (86/30) and a 20-30amp fuse for the relay to the pump?
Old Apr 21, 2008 | 10:56 AM
  #65
Nesiop's Avatar
Bump
Old Apr 23, 2008 | 04:10 AM
  #66
Nesiop's Avatar
Bump?
Old Apr 24, 2008 | 01:11 PM
  #67
FullBlown's Avatar
yes the hobbs is a negative trigger
Old Sep 2, 2008 | 05:33 PM
  #68
Jeeperjunior's Avatar
How long should it take for a professional shop to install one of these with a hobbs switch?
Old Mar 6, 2009 | 01:39 AM
  #69
haseeb's Avatar
is this fitting gone be the same if i had a jdm evo8 ,right hand drive ?
Old Jul 8, 2009 | 05:46 AM
  #70
mike1023's Avatar
Just wondering if i had done something wrong with the install? when i get about 1/4-1/8 of gas left. the 2nd pump seems to not get anymore gas? but the car will run fine if i just dont boost? little help thanks
Old Jul 8, 2009 | 06:55 AM
  #71
bbyevo8u's Avatar
at what whp level would you have to upgrade for the two pumps?
if i was at about 450whp could i stick with the single pump?
Old Jul 8, 2009 | 02:27 PM
  #72
Wheatley's Avatar
On 93 yes.
Old Nov 23, 2009 | 08:27 AM
  #73
awd2gen's Avatar
Im curious as to how you can wire this setup to run both pumps continuously. I don't like the idea of a pressure switch.
Old Nov 23, 2009 | 08:38 AM
  #74
stockevo03's Avatar
nice write up
Old Dec 6, 2009 | 06:52 PM
  #75
joel(PA)'s Avatar
is that single screw that holds the level sender to the aluminum bracket a metal screw or plastic? It looks plastic
I am installing this now, and i don't have that screw... i am afraid of using a metal screw and grounding it out...
also my kit is the plain aluminum... should i be worried about E85 corroding it?
