Cosworth IX Cams RULE ! My test
Old Dec 23, 2006 | 10:00 PM
  #46
TeamTurtle's Avatar
So...Jun over Cosworth? Because I'm comtemplating on what cams to get.
Old Dec 23, 2006 | 10:06 PM
  #47
hova00's Avatar
We have the IX Mivec Cosworth Cams on hand
I am offering a free custom tune with paid cams, install and dyno
Al
You are running a special with the purchase of these cams. Free tune that is pretty generous unless you are making up for the money somewhere else.
Old Dec 23, 2006 | 10:09 PM
  #48
EvOcHaRgeR's Avatar
I don't think Jun has cams out for the 9 yet...
Old Dec 23, 2006 | 10:28 PM
  #49
Frenchy4g63's Avatar
You could always just do an exhaust cam, any exhaust cam for the VIII will work on the IX. The only int/exh cams for the IX are Cosworth, GSC, and Kelford.
Old Dec 23, 2006 | 11:03 PM
  #50
eag36's Avatar
It was my car that had the cams put in and I love the low end torque. I think i've been convinced to do a test pipe and a cat back just for the top end. Here's the rough #'s without the graphs,
Baseline (no tune) - 257 hp & 270 tq
Cams (no tune) - 271 hp & 295 tq
Cams (tune) - 289 hp & 332 tq
The torque picked up from baseline to the final run was huge and the power comes on sooner than the baseline run too (after the tune). If you look at the chart that i'm sure Al will post up later, I'm definately restricted by the stock exhaust.
*Side note* - one of my spark plugs was found to be cracked and for lack of a better option we used STI spark plugs which were gapped a little hotter, but thankfully fit, otherwise i was going nowhere.
Old Dec 23, 2006 | 11:11 PM
  #51
EvOcHaRgeR's Avatar
So to say if it were a 35R with all supporting mods with tune I would see similar if not better results...
Old Dec 23, 2006 | 11:13 PM
  #52
eag36's Avatar
I may be wrong, but i think the cosworth cams are pretty well suited for the stock turbo, and if you have a bigger turbo you'd want 280's or S2's or the equivalent
Old Dec 23, 2006 | 11:35 PM
  #53
NocturnalEVO's Avatar
how would these cams be on a 50trim?
Old Dec 23, 2006 | 11:45 PM
  #54
-=SPECTRE=-'s Avatar
What dyno was this done on? I've heard some things about some dynos up north and some funky numbers going on.
BTW - Cosworth probably doesn't have it on their "roll of honor" but they were fired by their last customer in F1 (Williams) in favor of Toyota after several engine failures last season.
Old Dec 24, 2006 | 01:03 AM
  #55
DynoFlash's Avatar
Al
I was offering a special to try and get the cams on some cars and get some results to see if they were good or not
If they sucked I would have posted that information was well
Hapily they worked out well
Old Dec 24, 2006 | 01:48 AM
  #56
Bosshog's Avatar
search for my review. i got 39hp from cosworth cams and a retune with significant increase in torque. the other vendor you mentioned changed-improved their initial design after just one month. this almost made me think that they looked at some other-better cams in the market om how to improve the initial design. no surprise that the new cams have higher lift than the original ones (just like cosworth cams)
dont get mee wrong, i think its great that the company tries to improve their design, but a new cam in just one month seems hardly enough time to design something new to me
If you are trying to sell a product of course you are going to rave about how good they are so your not stuck with dead stock. I personally havent seen any posts about how great these cams except for this one. Maybe they are that good but my money would have to go with probably not but only time will tell. I think the Cosworth cams for the IX are comparable to the S2's that are going to be available from GSC and wont see there full potential until they are on an Evo with the right supporting mods.
Old Dec 24, 2006 | 02:04 AM
  #57
DynoFlash's Avatar
I have now added the dyno sheets to post one on page one
Sorry for thr lengthy delay - it was a long dyno day - its 5:00 a.m. and I just got home
Old Dec 24, 2006 | 03:04 AM
  #58
MR. Birdie's Avatar
so is these cosworth cams jsut drop in without the assistance of cam gears?
Old Dec 24, 2006 | 03:47 AM
  #59
dxbevo9's Avatar
Al...you mentioned that Cosworth suggested no need for the valveterain @ stock rev limiter...but isnt 272 considered a lifty cam? especially for someone who is running 1.7 bar of boost?
bosshog...did you instal any valve springs and retainers??
respect
Old Dec 24, 2006 | 07:44 AM
  #60
ROK EVO's Avatar
Thanks for sharing good info about Cosworth IX cams. I am now convinced that these cams provide good gains of 20~30 tq/hp. One observation, why does the hp curve start to drop off at 5500 rpm on the last graph with Stage II IX? Shouldn't it at least continue to go up until 6500 rpms?
