Cosworth IX Cams RULE ! My test
Today I installed our first set of Cosworth Evo IX cams and I am very impressed
There is no suprize why they do F1, Cart, Indy, WRC etc etc etc
The cams look better made right out of the box - they remind me of the JUN cams I have been using in my Evo
Our test car is a 2006 MR IX with
Knobby glacial grip snow tires
Down Pipe and 02 housing
Stock CAT and CAT Back - customer lives in draconian MA where modified cats and cat back are illegal
STOCK Air box
Walbro pump
MBC
Just dropping in the cams without ANY TUNING what so ever gets us 20 - 28 whp and TQ through the entire power band with the exception of the area below 3300 where we lost a tad of power
The idle is amazing - just right - its a bit racier but it is not agressive
The car "sounds" creat the sound of the cams inside the head has a really great "ring" that I can't describe but it just sounds for lack of a better word - "racey"
Adding some tuning quickly brings in the spool up area we are now making nearly 50 whp at 3,000 and almost 80 TQ at peak TQ
Of course this car is not going to show maximum potential of the IX as he has a stock cat and cat back but it does clesrly show me that the Cosworth Cam is a really quality unit and delivers the power
This is untuned - Stock Cams vs Cosworth Cams - boost exactly the same
This is the final tuned set up - notice the gains on the low end with some MIVEC adjustment (note the top end power is limited due to stock cat and cat back)
Just by way of control - and reference - this is a Stage II IX I tuned today - same dyno settings - no cams - which shows how badly the stock cat and stock cat back is hurting our IX with Cosworth Cams above.
My goal is to test the cams on a Stage II IX to see how much it gains over this
STOCK Air box
Walbro pump
MBC
I can only speak for myself - after seeing the Cosworth cams I will not sell or recomend any other
They are vastly superior to anything I have seen and the price point is very fair for what you get
retail is $640 and street price is lower
did you install both cams?not trying to be a smart aleck just that somebody told me you only install one cam due to the mivec, and what about a sprocket ,did you install a sprocket or planning to?thanks
STOCK Air box
Walbro pump
MBC
I will post up some dyno sheets later
Al
STOCK Air box
Walbro pump
MBC
Al
There are many ways to test things - we wanted to see what the cams do on a nearly stock car with no tune - just something that helps me learn about the cams and the MIVEC
This is only my first test of these cams
I will be doing additional testing when I get more cams
These few sets I just got took me two months to get after my initial order - I am sure that I will be testing them on more modifed IX's in the near futire
