what can i expect with 35R and meth?
Old Sep 10, 2007 | 04:35 PM
OtownEvo's Avatar
going saturday on dyno jet with retune and maybe kick up to 33 psi pm me after saturday will give you the numbers....
Old Sep 10, 2007 | 04:38 PM
OtownEvo's Avatar
here's a link to my install ...dyno graphs.....ect...
https://www.evolutionm.net/forums/sh...ht=buschur+35r
Old Sep 10, 2007 | 04:45 PM
EvOcHaRgeR's Avatar
I run 30.5psi with 93/meth on my 35r on my evo 9. Should be well over 500awhp but no awd available in alaska.
Old Sep 10, 2007 | 08:07 PM
EvolutionBoy67's Avatar
^How do you like it?
Old Sep 11, 2007 | 03:54 AM
psphinx81's Avatar
u could always just run 100 oct and bam a ton more power
Old Sep 11, 2007 | 04:30 AM
C6C6CH3vo's Avatar
Those turbos make power at high RPM, lots of power. Stock parts may eventually fail - like rod bolts. Probably 10X more likely.
Definately go throught the trouble of replacing those bolts (I heard you shouldnt replace from the bottom)
Old Sep 11, 2007 | 05:48 AM
duracell55's Avatar
I made 465whp on a low reading mustang dyno @ 30psi whith the stock ECU 93 + meth and I have a crappy 35R kit, you will probably be well over 500whp that was lots of fun! Made three 11.5 passes the same day with the best 60ft of 1.8 at over 120mph but I have a 9 and always had to shift to 5th (you will not have that problem, gotta love the Evo 8 4th gear)... The rest of the story is on my signature. Good luck!!!
Mellon Racing
579
Jul 31, 2024 11:57 PM
8-BallEvo
62
Jun 13, 2010 02:29 PM
Lucas English
41
Jun 11, 2007 01:24 PM
Derek888
44
Apr 10, 2007 08:23 PM
evodave
169
Feb 13, 2007 04:45 PM
