!!The Best BOV For evo 9 Recommend!!
Old Jan 1, 2007 | 01:24 AM
Vigo's Avatar
I was told by Patrick Robles of Forge Motorsport that boost response after shifting will actually improve if you vent to atmosphere. Forge says usually if it is possible to vent to atmosphere there are no downsides to doing so, as long as you are not using the stock MAF and also assuming that you are running a full stand alone engine management system.
Old Jan 1, 2007 | 02:23 AM
Silver05Bullet's Avatar
Stock Is Best Leave It Alone
Old Jan 1, 2007 | 05:38 AM
Jie-EVO's Avatar
thanks guys
what i really want to know is that what's wrong with my bov and what kind of after market bov does people run on there car !!!
Old Jan 1, 2007 | 05:45 AM
QuickSilver2's Avatar
Originally Posted by JohnBradley
On an VIII with the wrong BOV maybe. On a IX with the right one, No. My testing isnt fully complete but I had more hesitation and "bucking" with the stocker than I do now with my current test item. On the highway with low load, but just enough to where I was at 5"-0" vaccuum to 3 psi of boost, it would shake violently when I let off. It is now significantly smoother and not only that it is instaneous. I havent logged a sudden severe rich spike as apparently was the case with the VIII. It doesnt stall, bog, hesitate, or idle funny as I approach a stop. Spool is still the same and between shifts hasnt changed at WOT.
Your results may vary.
Do you mind sharing the name/model of your latest test BOV or PM it to me?
Thank you.
Old Jan 1, 2007 | 05:48 AM
Originally Posted by adrenaline1
lol some of u guys are really set on changing ur bov huh?
Yes. But only until and after due dillegence of research has been exhausted (pun).
No disrespect meant to anyone but as long as it is individually owned and not forum owned vehicles then all upgrade bets are off and are responsibilities of the individual owners.
YMMV.
Old Jan 1, 2007 | 05:59 AM
evo_08's Avatar
whats wrong with ur bov? i dont know. i run a tial bov.
Old Jan 1, 2007 | 06:10 AM
Jie-EVO's Avatar
it flutters throught every gear any rpm
Old Jan 1, 2007 | 06:30 AM
DRFTKNGG's Avatar
TIAL is tha bomb. Look at every race car and see what blow off they are running.
reliable.
Old Jan 1, 2007 | 06:31 AM
tuning g's Avatar
If it flutters at light load then you need a stiffer spring what is happening is that at light load you don't have enough spring pressure no boost to keep the valve closed so it flutters a stiffer spring would help
If it flutters when you shift only the spring is too stiff and it flurrer is comming through the turbo so in that case it would be a softer spring or you are not getting enough boost vaccum at the nipple.
Old Jan 1, 2007 | 06:37 AM
DRFTKNGG's Avatar
I use the stiffest spring available for the tial. No problems at all. works the best outta all the ones I have tried.
Old Jan 1, 2007 | 06:39 AM
Jie-EVO's Avatar
yea but i don't want to mess with springs because i don't want to over tide it or looseing it
Old Jan 1, 2007 | 06:40 AM
prostcj's Avatar
I haven't found one yet that doesn't either flutter or leak.
Old Jan 1, 2007 | 06:43 AM
Jie-EVO's Avatar
my's flutters all day long so ther has to be something wrong
Old Jan 1, 2007 | 06:48 AM
prostcj's Avatar
I have a forge that I'll sell you pretty cheap. It has three springs of different stiffness to choose from. It flutters at partial throttle but holds boost very well. I have only used the middle level spring. I wonder if I should try the stiffer spring....
Old Jan 1, 2007 | 07:11 AM
9sec9's Avatar
How about a DV for those who run 25-32 psi of boost but want to stay with a DV? What would be the choice?
