Afr Question
Old Jan 5, 2007 | 11:56 PM
  #31
Evoryder's Avatar
exactly..so you're tune is probably going to isht up top...unless u have like really really minimal advanced timing up top...
sounds like u don't have a cable or laptop...gonna have to find someone in your area to do the logs for you.
Old Jan 6, 2007 | 12:00 AM
  #32
ihatepotholes's Avatar
thanks for your help my friend... i'll see if sean ivey tunes Ecuflash.
Old Jan 6, 2007 | 12:08 AM
  #33
Evoryder's Avatar
Sean Ivey is the man...you're in good hands
Old Jan 6, 2007 | 11:19 AM
  #34
skoarpio's Avatar
[QUOTE=Evoryder;3829236]12.3 Is lean...u on meth or something? ...car needs to be tuned up top too...especially if your taking it well past 7000k
Dude what are you talking about 12.3 isnt lean thats kind of ideal if your boosting at that rpm and at 14. something yeah
your AFR is fine i would tend to go a little more rich but maybe 11.8
Old Jan 6, 2007 | 11:22 AM
  #35
skoarpio's Avatar
[QUOTE=housedj;3830398]ur optimum AFR on pump gas should be 11.5:1 flat across from full boost till about 6K rpm then begin to run RICH (maybe around 11.0 to 10.5:1) declining as u get closer to redline. ur current setup is a blown motor anyday now unless u get a retune!!!!!!!!!!!!!
I concur
Old Jan 6, 2007 | 11:23 AM
  #36
skoarpio's Avatar
Originally Posted by ihatepotholes
so u r saying... i should be getting decent amount of knocks?
knocks are bad muu kay??
dude if your knocking something is wrong and until you find out what it is (maybe your lifters do you have cams done?) i wouldnt race it
Old Jan 6, 2007 | 11:37 AM
  #37
Evoryder's Avatar
[QUOTE=skoarpio;3831302]
we'll see how fine he is once we get his logs...
Old Jan 6, 2007 | 01:19 PM
  #38
Boosted GP's Avatar
Running 21psi, 93 pump. 11.1till ~6500 then richens to 10.4 at 7800.
Mike
Old Jan 6, 2007 | 01:21 PM
  #39
Boosted GP's Avatar
edit
Old Jan 6, 2007 | 07:53 PM
  #41
jrsimon27's Avatar
in what gear do you see this happen
Old Jan 6, 2007 | 07:57 PM
  #42
BoostWhore's Avatar
sounds lean to me up top
lancerrally45
May 31, 2016 11:09 AM
MacMan
Dec 5, 2013 01:29 PM
EvoIXPilot
Apr 20, 2013 04:50 PM
mt057
Oct 25, 2010 12:22 PM
kmart888
Apr 14, 2010 11:26 AM
