Anyone using an eagle 94mm crank in a 2.2L stroker
Old Jan 7, 2007 | 05:36 PM
nitz's Avatar
curious to know if anyone has any experince putting together a 2.2L stroker kit using eagle's 4340 chromoly 94mm crankshaft. since this is large part of the cost for cosworth, jun etc 2.2 kits, could one just substitute in this crank? Any major builders doing a 2.2 shortblock with this crank?
2037005900B7 3.700" (94mm) stroker for 4G63. 7 bolt rear flange, 93-current engines $873.75
http://www.eaglerod.com/products/Mit...su%20rods.html
thanks
Old Jan 7, 2007 | 08:46 PM
bertune's Avatar
thanks
We recently did one on an evo 9, car is awsome, it made approx.470hp to the wheels(dynojet) so far and that is with stock cams at 21-22 psi. AEM! If u buy the crank, getting it balanced is a must, it was terrible.
Old Jan 7, 2007 | 10:51 PM
Frenchy4g63's Avatar
The 94mm Eagle crank is pretty new, but there's a few 2.2's around using the JUN stroker. It's a nice compromise between the 88mm 4g63 crank and 100mm 4g64 crank. I'm sure more people do 2.2's if it weren't for the $6500 price tag. I'm going to be using a K1 Technologies 97mm crank, K1 can also make a crank in any stroke you want by the way.
Old Jan 9, 2007 | 08:35 AM
nitz's Avatar
guess you can't expect too much from an $800 crank! can you price and spec a balanced 2.2L kit for me?
Old Jan 9, 2007 | 09:48 AM
Evo_SpeedKing's Avatar
amen to that!
Old Jan 10, 2007 | 09:50 PM
bertune's Avatar
Are u in miami also? U can call me and we can go thru the details!! Machines Gone Wild 305 256 1779.......Roberto.
EvilEvolution8
34
Apr 12, 2016 02:36 AM
usacchamp
14
Nov 22, 2014 09:23 AM
ZyBeR
11
Mar 6, 2008 01:36 PM
nianlala
30
Feb 5, 2007 10:14 AM
ZyBeR
Dec 14, 2005 10:29 PM
