High Idle
Old Jan 9, 2007 | 08:28 PM
evodrivesme's Avatar
High Idle
My car had been idling fine after my tune then about 2 or 3 weeks later i go out one morning and turn it on and it idles at like 1700, then it just keeps going up 2000, then 2400, then finally ends at like 2700. I can drive the car around for a little while and sometimes after about 10 15 minutes of driving it goes back down too like 1000, 900 range.
It also is kind bouncy sometimes up and down, like 1700 to 2400 up and down constatly. I had this problem on a honda i use to have and it was the idle air control valve but it never would stay pined at 2500 for a long period of time it would just bounce.
I know this cant be the tune, its not like the computer can just change it self like that.
Old Jan 10, 2007 | 09:17 AM
guess no one has had this problem humm
Old Jan 10, 2007 | 09:23 AM
Ryu123's Avatar
I had the problem of the bouncing RPM at a stop after driver the car hard. I think it has to do with the ISCV setting Don't know how to fix it though.
Old Jan 10, 2007 | 09:39 AM
evo150's Avatar
have you checked for vacuum leaks?dont have the heater set to defrost do you? no CEL?
Old Jan 10, 2007 | 09:46 AM
AndyBandy's Avatar
mine was actually a throttle body gasket leak
Old Jan 10, 2007 | 09:53 AM
hondafan's Avatar
sounds like a vacuum/boost leak. do a test.
Old Jan 10, 2007 | 11:05 AM
i will check for a vacuum leak when i get back to the car but i meen i have checked all the vacuum lines and everything seemed to be ok.
Old Jan 10, 2007 | 12:45 PM
Aby@MIL.SPEC's Avatar
the 2500-2700 number sounds as if the iac took a dump.
see if you can borrow 1 from a buddy w/a evo. it takes ~5 minutes to swap out.
once fired up the car to see how high the car would idle with teh aic disconnected, it was 2700 revs!
good luck
Old Jan 21, 2007 | 05:14 AM
now the car wont even idle it just dies out. car hasnt moved since it was doin that weird high idle almost 2 weeks ago.
Old Jan 21, 2007 | 05:24 AM
mikerobave's Avatar
i have the same problem alot. On mine, its the main throttle body butterfly valve. I take off the IC piping and clean it out with a toothbrush and some cleaner. I think it has to do with my methanaol injection but apparently it keeps building up "gunk" no matter how many times i clean it. It wont let the throttle body close that extra 1/8 of an inch or so. Usualy builds up after 2 weeks. I noticed u had meth injection as well so it might be something to check into.
browningderek
AEM EMS
73
Mar 2, 2019 08:35 PM
Srt-4 Turbo 7
Jul 18, 2013 07:36 AM
ethan169
Mar 2, 2012 10:37 PM
EvoJoeIX
Nov 8, 2010 08:51 AM
c900t16
Lancer Engine Tech
12
Mar 5, 2007 07:24 PM
