EVO IX Cosworth Cam Dyno Results
Old Jan 15, 2007 | 03:30 PM
  #31
dudical26's Avatar
Thanks for the testing and info. These results seem a lot more realistic then what others are claiming. About 15hp from cams is not bad, but I would say for most people it is probably not worth the money.
Old Jan 15, 2007 | 04:47 PM
  #32
BoOsTinGEVO190's Avatar
is all of this on a stock clutch?
Old Jan 15, 2007 | 05:13 PM
  #33
kouzman's Avatar
Yes stock clutch, but of course it slipped some times...
To tell you the truth i was quite impressed by the stock clutch, but then it only has 5200 miles on it, lots of them are highway miles and its only launched once...
I don't think it will hold continuous abuse so currently i am saving for an ACT kit...
Old Jan 15, 2007 | 06:31 PM
  #34
stock clutch
so you putting a test pipe would give you about 10 whp?? how about TQ did al tell you about between what #
Old Jan 15, 2007 | 07:01 PM
  #35
kouzman's Avatar
If you mean torgue with the testpipe i don't know. i guess similar gains with the whp...
Can't wait to add more bolt ons on the car...
Originally Posted by BoOsTinGEVO190
stock clutch
Old Jan 15, 2007 | 10:59 PM
  #36
2JZfan's Avatar
Originally Posted by DynoFlash
I did not care for the Mivec mapping and adjusted it and netted some more power with a loss of a bit spool up in the low end.
This was all done on the stock cams - note this customer has a high flow cat which typically costs about 10- 12 whp in my experience.
AL
Al, can you expand on the above concept a little more... since the mivec is adjustable throughout the rpm range, why do you have to do "one or the other"? Why couldn't you have stuck with the previous settings in the lower rpm range ( < 3600 ) and went with your settings in the mid/upper range to get the best of both worlds?
mrm95
Jun 2, 2016 07:21 AM
vince126
Canadian Forum
24
Dec 3, 2014 12:59 PM
BEISSEN
Sep 6, 2013 07:57 PM
11secDSM
Jun 6, 2009 04:54 PM
GT35REVO8
For Sale - Cars For Sale
May 28, 2007 08:18 PM
