Trouble Code PO401?????
Old Jan 16, 2007 | 04:07 PM
evo ippo's Avatar
Lightbulb Trouble Code PO401?????
my cars keeps throwing this code and i can't figure out whats wrong i know the code says exhaust gas recirculation flow insufficient.
but where can the problem be and is it a big problem???
Old Jan 16, 2007 | 04:09 PM
3SgteGuru's Avatar
EGR, you probaly blew the vacuum off that goes to the EGR. Look Around the EGR valve and see if you see some unplugged vacuums.
Old Jan 16, 2007 | 04:10 PM
purevibez's Avatar
do u have a factory bloww off valve
Old Jan 16, 2007 | 04:12 PM
evo ippo's Avatar
a newbi question where is the EGR valve??? and i have a HKS SSQV Version 2 with a Pipe
Old Jan 16, 2007 | 04:14 PM
purevibez's Avatar
i get it with the tune i have now every few weeks when driving very easy in like traffic.i spoke to a few guys and they said its probably my aftermarket blowoffvalve. i had the egr problem once too. fixed it by putting the vaccum line back on. but i still get it every now and then. they say the stock bov releases pressure with the lightest let off the gas. the after market ones dont. just passing it on. if im wrong please correct me.
Old Jan 16, 2007 | 04:18 PM
kreionic's Avatar
Search there are so many threads about this but here
reach behind the throttle body. There will be a nipple back there feel for it. Reach down a little farther and there will be a vacum line there. Plug it in the nipple , zip tie it and your good to go. You can't see it so its all done by feel.
Old Jan 16, 2007 | 04:19 PM
evo ippo's Avatar
sounds like i am going to molest by evo later on today
Old Jan 16, 2007 | 04:22 PM
kreionic's Avatar
Yeah it sounds kind of weird. Make sure you wear protection
Old Jan 16, 2007 | 04:27 PM
QwikEVO's Avatar
If you do a search on P0401, you will find more than a few threads already about this subject. There are pictures of the EGR valve and a description of it's location to help you out.
Also in the future, any CEL codes you get...if you do a search, you will most likely find many threads already started about that particular code and how to fix them...
Evoryder's Avatar
Search!
Old Jan 16, 2007 | 05:45 PM
evo ippo's Avatar
ok guys thanks i found the vacum tube that pop off so i put it back in and zip tied it down........ my car looks like a driffter now some many zip ties i should buy some stock in it hahahahha.
one thing does that EGR can it release boost pressure at all, or boost has nothing to do with the EGR? because i have my car setup right now with the new evc and i think that the vacum line fell off before we tune the evc.
Old Jan 16, 2007 | 05:47 PM
QwikEVO's Avatar
Others can correct me if I'm wrong, but I don't think boost has anything to do with the EGR. It's all emissions stuff.
Old Jan 16, 2007 | 07:28 PM
C6C6CH3vo's Avatar
Perhaps you can use these to find the problem
Basically the EGR vavle is a metal valve with 2 nipples and looks like a small DV. Located below and behind TB.
There's a 3 way solenoid that controls it so it so it closes under boost. If the vacume line that pulls on the diaghram is off the valve wont open and you'll get "insufficient EGR flow"
GhostEvo^X
Jul 8, 2017 12:17 AM
Brsox10288
Feb 26, 2009 01:31 PM
dahuii77
Aug 18, 2008 11:21 AM
Evo8Emperor
Mar 13, 2008 01:00 AM
EVOMIZ
13
Mar 8, 2004 01:51 PM
