max boost on stock head gasket?
Old Jan 16, 2007 | 08:21 PM
App420's Avatar
2.3 liter built motor, ported and polished head, stock turbo for now, and planing on 35r kit. will run alky occasionally. I am curious if the stock head gasket would hold the high amounts of boost well. If not I am curious what recommendations you guys may have. Any input is valuable and appreciated.
Old Jan 17, 2007 | 04:21 AM
App420's Avatar
bump anyone?
Old Jan 17, 2007 | 04:41 AM
SIGSP2340's Avatar
As long as you have ARP head studs your stock gasket was properly seated/sealed you should be fine for 20-30+lbs of boost.
Old Jan 17, 2007 | 07:51 AM
Gusl's Avatar
I believe AMS runs the stock head gasket on there cars.
Old Jan 17, 2007 | 08:05 AM
Ted B's Avatar
With pump fuel, you won't be able to run more than 22-23psi with a proper tune, so it's a non-issue.
With a shot of methanol, you'll be able to run more boost, but this is still a non-issue.
The factory gasket isn't a composition type, and isn't prone to failure. The biggest threat to the integrity of any head gasket (aside from poor tuning) is improper surface finish and/or improper head fastener torque.
Old Jan 17, 2007 | 08:15 AM
Ultimate CC's Avatar
boost is not the only thing that effects that, timing does as well...
Old Jan 17, 2007 | 10:35 AM
App420's Avatar
thanks for saving me some money guys!
bab090
38
Jul 19, 2013 03:35 AM
svt_lightning01
Dec 7, 2011 09:29 PM
KY
12
Nov 29, 2010 11:46 AM
imalancerman
Lancer Engine Tech
Jun 5, 2009 10:35 PM
Sti THIS
21
Oct 28, 2007 02:04 AM
