Benefits of LICP
This has been discussed before and no one was able to provide any real data showing any appreciable gains.
I can see it both ways. On one hand you are shortening and straightening the pipe so it should improve response but, on the other you are increasing diameter rapidly which could cause turbulence and decrease velocity into the intercooler. So who knows.
This makes the compressor of the turbo push air more easily and because THE COMPRESSOR AND TURBINE ARE CONNECTED a given unit of exhaust energy put into the turbine wheel can spin the compressor wheel more easily because of reduced friction on the compressor side.
voila, spool is decreased
if you would like some equations i can supply those too
The Lower Intercooler pipe is one mod you want to do asap. It frees up alot of flow in the system. The OEM LICP has mani bends and the piping is very small in diamter out of the turbo outlet. Nisei Engineering is the BEST LICP on the market. Has been tested many times and been proven.
Yea, I experienced about 10whp from the Nisei pipe myself. And posted logs but that wasnt good enough for the naysayers and eventually I decided I didnt need to convince the naysayers. The Nisei LICP works, not sure about other pipes as I dont have any first hand experience with them.
It would spool quicker... less restrictive bends and shorter piping = better spool.
Here's a picture to help illustrate what the guys above are saying:
By increasing the piping diameter earlier in the system, resistance is decreased and flow is improved. Flow is further improved by making that expansion prior to the tight radius bend required for the piping to clear the factory undertray. Such a tight bend is not ideal, but by using full 2.5" piping through the bend rather than expanding after, flow is maximized given the tight radius with which we have to work
Tom
Tom
yeah, I put down 350whp back when my Evo IX was bonestock, just by adding a LICP!!!!11!!!! and that's BEFORE the tune!!
No, seriously -- I have the Nisei LICP and didn't notice a damn thing
-- no increased spool or power, despite the fact that I was already biased that I would... Still have the stock IC and UICP, and don't plan on changing
i did a speed source licp, necks down a lil which kinda sux(but i bought it on impulse) but i noticed the throttle response and spool to be much better, if u see a stock one compared to an aftermarket one, u will put it on immediately. imo its worth the 160 bucks
Black_EVO_MR
Oct 18, 2014 06:23 PM
daechul2da
Oct 24, 2009 07:32 PM
modetm
27
Oct 1, 2009 04:55 PM
Seems like just another way for us to spend our money foolishly
