ss clutch line install.. Do i need more brake fluid?
Old Jan 24, 2007 | 01:42 PM
ChuckP's Avatar
So im about to install my ss baided clutch line and got a couple questions.
Is my master cylinder going to drain completly when i get the hose off?
If so how much brake fluid will i need to replenish it, and should i pay the premium for OEM fluid or can i use some DOT 3 from kragen? Thanks guys.
Old Jan 24, 2007 | 02:57 PM
Evil_1's Avatar
It is a PITA to replace that ss line. You'll probably end up going through 1 to 2 bottles of fluid depending on how much bubble is in the line and how easy it is to get all the bubbles out. I just use fluids from the auto parts store that meets or exceeds Mistu's specs. Have fun
Old Jan 24, 2007 | 03:08 PM
evo-mutsumiko's Avatar
no it will not drain all of your fluid. i bought 3 bottles just cus i wanted extra. it only took less than one bottle, and i bled the clutch and brakes. if you change the brake fluid to a different kind you not only have to bleed the clutch but you have to bleed the brakes too (well, its recommended)
install: http://evomoto.com/tech_info.php?tec...d2d5316c2be26e
Old Jan 24, 2007 | 03:18 PM
ChuckP's Avatar
OK, Did you guys remove the plastics under the car and put an oil pan below? Im just wondering if all my brake fluid is going to come rushing out when i get that tranny mounted piece with the restricter in it, off. I know i need to bleed the clutch, but will i really need to bleed the brakes too? thanks
Old Jan 24, 2007 | 03:24 PM
its recommended....i bled the brakes cus i need to anyway. you don't have to remove the plastic. if you put the car on jacks or ramp you can reach it with rachet and extensions(i had to use 2... 4 incher). after i got the bolt loose i put a oil pan under the car and let it drain. its only a little fluid though
Old Jan 24, 2007 | 03:26 PM
brake bleeding: http://www.joe250.com/cars/evo/brakebleed.htm
clutch bleeding: http://evomoto.com/tech_info.php?tec...d2d5316c2be26e
Old Jan 24, 2007 | 06:45 PM
ChuckP's Avatar
good lookin' im gonna get on this tomorrow.
Old Jan 25, 2007 | 06:05 AM
Jakeg97's Avatar
yes
no
only need 1 bottle of brake fluid
get the HELP speed bleeder. makes it much easier to do
Old Jan 25, 2007 | 06:13 AM
Jakeg97's Avatar
you can also use DOT 4 which has a higher boiling point and its safe to mix with DOT 3.
sells for cheap at walmart 2
Old Jan 25, 2007 | 06:17 AM
Jakeg97's Avatar
Originally Posted by evo-mutsumiko
other thing
removal of the restrictor will give you a feel, imo, of a new clutch
and clutch engagement will be quicker and with more force
Old Jan 25, 2007 | 12:51 PM
ChuckP's Avatar
Yeah i plan on taking out the restrictor while im at it, thanks for the quality info in the last few posts, all i need now is someone to help me bleed...
Originally Posted by Jakeg97
other thing
Old Jan 25, 2007 | 12:53 PM
ChuckP's Avatar
What speed bleeder is reccomended for the clutch?
yes
no
Old Jan 25, 2007 | 03:32 PM
for bleeding i didnt get a speed bleeder...auto store didnt have one but i think on one of the links i put up it gives you a part # if not go to evomoto.com and look up clutch bleeding
polish_pounder
Jun 16, 2014 04:01 PM
jason42003
Dec 19, 2013 05:15 PM
pocoRA
04-06 Lancer Ralliart How To Requests / Questions / Tips
60
Mar 2, 2012 09:00 AM
VrMPSHHH
Aug 4, 2011 08:52 PM
Evo11V
Sep 25, 2003 10:05 AM
