Rev limit on the 4g64 crank
Old Jan 27, 2007 | 08:40 AM
Sax's Avatar
Sax
Hello, I need know what is the rev limit on the 4g64 (2.0 stroked to 2.3) crank.
Thanks
Old Jan 28, 2007 | 10:55 AM
noahrexion's Avatar
The 4G64 and 4G63 cranks are different. Each OEM 4G64 had different variations of rev limits imposed by Mitsu (usually a hair past 6k).
The build of the motor, tuner and actual builder (who knows what kind of rod/piston, CR and gasket combo you are using) should probably help with that.
Old Jan 29, 2007 | 01:12 PM
Karacing's Avatar
first off, 4g64 is 2.4L, and the rev limit is 6k, and with an evo head its 8 easily
Old Jan 29, 2007 | 01:21 PM
Karacing's Avatar
oh sorry i just read it more clearly 4g64crankblock+4g63 doheadcam i was referring too
Old Jan 29, 2007 | 05:52 PM
trinydex's Avatar
8k easy?
Old Jan 29, 2007 | 09:30 PM
dsycks's Avatar
Yeah, but just 1 time.
I must say that I am interested in this to the extent that I want to make loads of power down low and am willing to give up some top end for it.
Old Jan 30, 2007 | 03:10 PM
Sax's Avatar
Sax
Evo 6 block + Evo 6 Head + 4g64 crank
Old Jan 31, 2007 | 05:54 AM
Karacing's Avatar
Originally Posted by trinydex
8k easy?
yes 8k easy, i forgot but there was a magazine that showed an evo 4g64+evo8head and gt35r turbo running 700whp
Old Jan 31, 2007 | 05:58 AM
Karacing's Avatar
yes evo blockhead+4g64 crank thats a stroker but it wouldnt give as much power i think as my setup i was talking about
Old Jan 31, 2007 | 06:45 AM
dsycks's Avatar
Links? Dyno sheets? Pics?
Old Jan 31, 2007 | 08:14 AM
Fourdoor's Avatar
I would not hesitate to run 8K on that crank as long as it has a light weight forged piston and rod set that is perfectly ballanced.
Keith
Old Jan 31, 2007 | 01:22 PM
homemade wrx's Avatar
ams says to not spin past 8500 on their 2.3L but then again they couldn't tell me any technical specs of weights of any of the components of the motor...they said they don't even balance their shortblocks...
Old Jan 31, 2007 | 04:54 PM
trinydex's Avatar
so all we have to go on is hero pulls and heresay... anyone have hard number or facts on actual kits in use that have been roadraced... no dyno pulls or drag coasts.
Old Jan 31, 2007 | 07:29 PM
Knightracer's Avatar
I have never road raced my car but I do have a AMS 2.3 kit in my motor. I had the internals and new crank all balanced before having the motor assembled. I have 1800 hard miles on my car and I shift at 8500 to 9000rpm. Granted my motor doesn't have 10,000 miles on it but my miles are hard miles, and I haven't had a hint of problems. I guess time will tell.
Old Feb 1, 2007 | 03:53 AM
4ringturncoat's Avatar
The crank is not so much the issue, it is the high pistons speeds with a 100mm stroke. I would be more concerned with rod bearings and rods then the busting the crank.
