Ams Gt37r Kit Or Buschur Gt37r Kit?
Old Feb 13, 2007 | 10:27 AM
  #91
High_PSI's Avatar
I believe Daves's new 35R kit may be the end all be all of the 35R kits. The trouble with Daves kits is that they are not as BLING as AMS, the cast manifold turns off a LOT of people. But it works VERY well and won't break like tubular manifolds do. it also keeps the cost down. Dave only gives you what you need.
  #92
Phil_FQ's Avatar
I am running an AMS GT35R and i have to say i have been very pleased with it...Spool up is great, full boost (2.25 bar) built by 3600rpm or so..Ran 687bhp with a slipping clutch 2 weeks ago on this kit...
Phil
Old Feb 13, 2007 | 10:32 AM
  #93
Jrod@Buschur's Avatar
We can do a tubular, ceramic coated exhaust manifold as well if that is what the customer wants. It would change the price of the kit to $3695 and the ceramic coating is an additional $100 option.
Old Feb 13, 2007 | 10:40 AM
  #94
High_PSI's Avatar
Phil
Please post your log, I would like to see a 35R hit over 30PSI by then. That would be AMAZING.
Old Feb 13, 2007 | 10:50 AM
  #95
Phil_FQ's Avatar
Excel sheet using the raw data from the run..I only got one run on a slipping clutch before it let go completely..The RPM pickup was getting a lot of feedback hence there is no RPM fig only a speed reading. Had to work the RPM back from speed but its 100% accurate
Old Feb 13, 2007 | 11:30 AM
  #96
EvoRecordSetter's Avatar
Originally Posted by davidbuschur
evoracingstar........................look who has a Dynojet and look who has Mustang Dyno. If dyno numbers meant anything that we wouldn't be the fastest.
Thanks for the input though.
Tomorrow hear comments like "On the mood a Dynojet's correction factor is the same as a Mustang Dyno on your Anus"
you being familiar with dyno's and having such a following, shouldnt you encourage people to use dyno's and there numbers to test/compare gains for a person to record there power. then from there make changes and use the dynos to test and record power gains, or loss', to help improve ones car.
i believe all dyno's are different with each model being similiar, but to have a "pissing contest" with who can make bigger numbers on different dyno's is silly IMO.
Old Feb 13, 2007 | 11:34 AM
  #97
first time ive seen 30 psi by 3600 rpm on a gt35... also first time ive seen it in excel. was this dyno done in 5th gear?
Old Feb 13, 2007 | 12:25 PM
  #98
David Buschur's Avatar
Excel spreadsheet to make a boost chart, I believe I have seen it all. A GT35r, unless hit with nitrous, anti lag or a 2 step is not going to hit 30 psi by 3600 rpm, end of story.
I've dyno'd plenty of AMS turbo kits here, it doesn't happen with theirs, ours or anyone else's. Not even on the planet youranus.
Old Feb 13, 2007 | 12:45 PM
  #99
Vigo's Avatar
That's with third gear. The reason why it spools so soon, is because he has a 2.4L stroker kit.
Old Feb 13, 2007 | 12:51 PM
  #100
Vigo's Avatar
To maintain stock like spool up time with a GT3076R turbo you should mate it with a 2.3L stroker kit. As for a GT35R turbo, combine it with 2.4L stroker for close to stock like spool up time. The British guys are really into road racing, so boost response is a key deciding factor over there. That's why many people are running strokers in Britain. Also, average speeds on the streets in Britain are much lower, so low end power is very important to them.
Old Feb 13, 2007 | 12:54 PM
  #101
Vigo's Avatar
I would vote for a Buschur Racing GT35R turbo kit, because of the cast exhaust manifold and cast o2 housing. Those parts are much less prone to cracking than tubular.
Old Feb 13, 2007 | 01:07 PM
  #102
4g63girl's Avatar
If i could post anything without getting banned i would. with that being said buschur kit hands down!
Emery
Old Feb 13, 2007 | 01:12 PM
  #103
Phil_FQ's Avatar
David if you don't believe it thats your problem not mine...No Anti lag, N02 or anthing like that were used....
I was only saying what i found on a set of independant DD rollers conducted in shootout 44 mode...I am not saying your kit is bad in any way, i am sure it is extremely good...
You go and work out the RPM from the gear ratios for a std Evo VII and see if i am wrong wheel diameter is 225/40/18 3rd gear ratio is 1.407 final drive is 4.529
Note where peak tractive effort is on this graph as well.
Old Feb 13, 2007 | 07:23 PM
  #104
evoracingstar's Avatar
Ams !!!ftw!!
Old Feb 14, 2007 | 07:22 AM
  #105
*sam*'s Avatar
Originally Posted by evoracingstar
Ams !!!ftw!!
+1 AMS all the way!!!
