why do honda engines make so much more power with less boost
Old Feb 8, 2007 | 02:12 PM
  #46
A418t81's Avatar
Originally Posted by Spooldyou
ok there are no such thing a 4g63 non Turbo, The motor that came in standard with the Rs' and non turobed Eclispes, Laser's and Talons, all had the engine code for the 420a, Thats the same motor that was in the Dodge Neon, and Chryslers POS motor that always blew the head gaskets. So you need to check your info again.
There sure is a 4G63 non turbo, and they weren't just in Mitsu's. Check out a 92 Sonata
Old Feb 8, 2007 | 02:15 PM
  #47
Recks's Avatar
Also my car would be revving to 9800 rmps.. Honda man they are crazy motors!
Old Feb 8, 2007 | 02:16 PM
  #48
riceball777's Avatar
Originally Posted by anjapower
it's probably the integrity or lack thereof of the open deck aluminum block with such high boost.
with a sleeved honda motor, I don't see why they couldn't run the boost that Evos do on pump.
that most defintally is not it
even sleeved hondas never boost 20-23 psi like that of the evo on 91 octane pump
sleeves have nothing to do with it. hondas can make 500-600whp on stock sleeves with no problems.
Old Feb 8, 2007 | 02:20 PM
  #49
Originally Posted by Recks
Before I got my evo I was working on building my k20a2 turbo! Rods sleeves pistons, the works. And a 35R turbo kit. Car would be pushing roughly 20-22 psi and would make around 400-500 whp... That's fully built and after 10k in labor and mods.. So I didn't do it and bought a turbo car.. Hense the evo lol!
the k seris motors are defintally one of the best 4 cylinder motors ever made. it even surpasses the b seris. but the evo is a better car.
i'm not bashing on evos. i love my evo way more than my integra. its more practialy and has traction and is great is every aspect. but from everything that i seen and read it just seems as if honda motors both the b seris and espically the k seris are superior to the 4g63 in both efficeancy and power production
Old Feb 8, 2007 | 02:24 PM
  #50
Ted B's Avatar
Originally Posted by riceball777
yes its true. and i would like to know why
it is completely unheard of if not impossible of a honda to run 20-23psi of boost on 91 octane pump gas like that of the evo even when the honda has the same low compression like that of the evo
Obviously, neither of us know enough about the Honda motors to come up with clarification on our own. This question is best asked in a Honda forum, where I'm sure one will get a quick answer.
  #51
badhabit90's Avatar
cylinder head flow.
where WE dont have a vtec in the evo8, you with the b18c or LS engine, have basically a second set of cams. the VTEC engages and allows MORE airflow at a given psi. it is NOT the psi, but the airflow. why do you think the 35r AT THE SAME BOOST LEVEL OF SAY 24PSI MAKES MORE POWER THAN THE STOCK TURBO AT 24PSI??
you have to take into account EVERYTHING being the same. this comparison as TED pointed out, it cannot be. everything is NOT equal. unless you have two engines built to EXACTING SPECIFICATIONS I.E. compression, piston cc, cylinder head cc, chamber cc, etc. we will continue to debate-"welp, i have this friend that has a friends engine in hiz civic that went on pinks and it waz like putting down 600hp yo...so he needed 20 cars to beat teh trans am...FTL" hahaahaha!!!! had to put that in there.
there are too many variables to compare.
  #52
KOEvo's Avatar
It's just hard for me to relate to and understand the whole "better flowing head" concept because frankly, as the OP said, if ANY PART of the Honda engine outflowed that of the 4g63 (w/ the same comp. ratio, mind you) it would be able to efficiently and safely run more boost/timing than the 4g63. More efficient motors can safely be tuned more aggressively, correct? So i think the whole "better flowing [insert anything]" needs to go out the window right now.
I wish this thread had a better title to it so more educated people would participate. 99% of the Evo community doesn't give a **** why a Honda engine makes more power on less boost... But i as i'm sure others, have always wondered the answer to this question; for all cars/motors in general.
Originally Posted by Ted B
No, it isn't smart, and reflects a lack of understanding between manifold pressure and ignition characteristics.
Anyone can run 30 psi on pump fuel, but they have to retard the ignition timing to do it. The catch is they won't make any more power than with 22-23psi and a more realistic ignition map.
What they don't realize however is with all that ignition retard, they will experience very high EGT, and they're just slowly destroying their exhaust system and turbo will all that heat.
OT, but what happens if you max out timing and barely run any boost?
Old Feb 8, 2007 | 02:38 PM
  #53
Ted B's Avatar
Not really.
More volumetrically efficient motors flow more air mass (make more power), all else appearing equal.
Old Feb 8, 2007 | 02:39 PM
  #54
hotrod2448's Avatar
Nobody has mentioned cam design. Maybe the Honda's have a much wider LSA causing them to effectively have a higher compression ratio and take less boost.
I'm sure Vtech does play a larger role in making power up top as well. Look at what Mivec did for the IX and it only controls timing on one cam never mind lift and duration.
They do seem to consistently make less torque than the 4G63 though. I think that the difference in stroke plays a role in that.
Old Feb 8, 2007 | 02:41 PM
  #55
badhabit90's Avatar
Cool
not necissarily. it may induce knock and you have your MAX output tune safely. sure you could have MORE boost, but at what engine part expense?? you more than likey will bend a rod from knock or break a piston.
again, it depends on the knock threshhold. if you see too much knock then you have to pull timing or you will surely hurt the engine. you can lower your boost settings in some cases and make MORE power because of the incoming air temp from the turbo. you could bump timing up a little-again-until you see knock.
anyone can claim they made 500whp. sure it was PEAK and not overall. lets see what the averages are of the same set up for the b series and the 4g63 series engines and THEN look at it again. only this time use an EVO 9 engine and head...
Old Feb 8, 2007 | 02:42 PM
  #56
stroke is relativly the same
evos are 88mm stroke
honda ls motors are 89mm and gsr/typr r's are 87mm
  #57
Ted B's Avatar
'Maxing out' the timing would correctly refer to setting the timing such that peak combustion pressure is generated when the piston is ~15deg ATDC. Advancing the timing further makes no more power (only creates detonation), reducing the timing makes less power.
For any given fuel octane and manifold pressure, that setting which creates peak pressure at the aforementioned point makes best power. If the fuel octane cannot withstand it, the timing must be retarded.
At 30 psi and pump fuel, the timing cannot be set anywhere near that optimum point. It must be delayed so far, that fuel is still burning when the exhaust valve opens, creating excessive heat (and no additional power).
Old Feb 8, 2007 | 02:43 PM
  #58
BlackIX's Avatar
90-94 DSM's came with 1.8L SOHC, 2.0L DOHC N/A and 2.0L DOHC Turbo. That was the engine/car I was reffering to, not the 2nd gen DSM's with the 420A.
  #59
badhabit90's Avatar
edit:
TED B you beat me to it
"More volumetrically efficient motors flow more air mass (make more power), all else appearing equal."
Old Feb 8, 2007 | 02:46 PM
  #60
hotrod2448's Avatar
You grasp the concept of a larger turbo making more power with less boost but, you can't see how a better flowing head/engine can out flow another head/engine and have lower manifold pressure at the same amount of flow.
If one head is a restriction of course it is going to have a higher pressure level (boost) than one that flows better given the same amount of volume to flow.
