Fuel cut with stock boost lines?
Old Feb 12, 2007 | 06:35 AM
EVIL_EVO_VIII's Avatar
Well i finally got to install some parts on the IX this weekend.. I installed a catless tbe and a o2 housing, nothing else and NO mbc.. I was making some test runs to see how the car felt and i hit fuel cut in 4th gear but, this ONLY happens if i start in 3rd gear and make a pass all the way to 4th... I thought by having the stock boost lines, it would regulate the boost to not go pass the factory settings? Ive never had this problem before. Im assuming its bc i have more air flow now.
Old Feb 12, 2007 | 07:38 AM
Bump
Old Feb 12, 2007 | 09:05 AM
jmartinez1170's Avatar
Just get the car flashed and you wont have this problem.
Old Feb 12, 2007 | 09:08 AM
Im getting it flashed this week sometime. Just waiting to throw in the mbc and fp in
Old Feb 12, 2007 | 09:20 AM
Sounds good. Why dont you buy lower and uper IC pipes just to insure you have no leaks.
Old Feb 12, 2007 | 09:32 AM
TeStUdO's Avatar
Or you could just install T-bolt clamps and do a boost leak test to save a few hundred dollars.
Old Feb 12, 2007 | 09:36 AM
Im not going to get into it. But the airflow and ic pipes happend to be a lil better then stock. Do some searching you will find out.
Old Feb 12, 2007 | 09:39 AM
The.alibi's Avatar
Do you have a boost guage ?
Old Feb 12, 2007 | 09:43 AM
Yes
Old Feb 12, 2007 | 09:49 AM
EVO8emUp's Avatar
The way its worded, you make it sound like the stock pipes leak.
If the clamps are tightened properly, they don't leak.
If it is in fact hitting fuel cut, installing parts to increase airflow even more is not going to help.
Old Feb 12, 2007 | 10:12 AM
The.alibi's Avatar
Yes
Explanation:
Then you should have noticed a slight increase in boost since the TBE install, your ECU is not ready for these changes. Fuel cut doesn't really have much to do with fuel, if your ECU is reading more airflow due to increase boost pressure it will cut fuel in an effort to prevent overboost and outboosting the stock fuel system.
Solution:
Get tuned
References:
https://www.evolutionm.net/forums/sh...d.php?t=250656
https://www.evolutionm.net/forums/sh...d.php?t=250782
https://www.evolutionm.net/forums/sh...d.php?t=238807
https://www.evolutionm.net/forums/sh...d.php?t=176239
Hope this helps you !
Old Feb 12, 2007 | 10:16 AM
Explanation:
Solution:
Get tuned
References:
Thanks man Getting tuned this week
Raceghost
Jul 29, 2016 12:04 PM
dac001
Jan 6, 2010 01:07 PM
dragon831
Jul 24, 2009 07:09 PM
TonyG
Apr 10, 2004 07:24 PM
sir lurks alot
Nov 6, 2003 06:26 AM
