Car runs rough...
Old Feb 18, 2007 | 04:09 PM
riceball777's Avatar
map is manifold absolute presure
Old Feb 18, 2007 | 04:13 PM
Originally Posted by Evo442
My VIII has done this for as long as I can remember. Stalls like that too if the rpms drop too much. Was worse with an aftermarket BOV, so I went back to stock. Also happens when I put the car under load (ie. accelerate) from a stop/near stop and then suddenly put the clutch back in...
ie being at a stop on a hill, launching the car forward a bit, and then putting the clutch back in - rev's will drop, sometimes the car will stall. Some evos do this worse than others, I've been told its pretty normal.
If anyone finds a definitive answer, I'd like to know it!
mine does the exact samer thing. and its a lot wore if the ac is on.
if i acceperatea little and put the clutch back in right away the car will get pig ritch and stall. does this even worse when its on a hill. i think it has something to do with running an after market intake and with the maf. i have an hks intake btw.
Old Feb 18, 2007 | 04:17 PM
DRFTKNGG's Avatar
^^^^because BOV opens and vents metered air out...
Old Feb 18, 2007 | 04:35 PM
xmaciek82x's Avatar
Originally Posted by Spikedlee
I've got the same exact mods as you and after I had the K & N put in the car ran like **** until I got it tuned recently. The boost wasn't holding, the power was horrible, etc. After the tune it ran perfectly and was very smooth. I say get a tune.
You get a base tune or a custom one? I was going to go with the AMS base one hopeing that will fix the problem.
I don't want to do a custom tune just yet, I will wait till I do more things with the car first.
Old Feb 18, 2007 | 07:18 PM
3SgteGuru's Avatar
Originally Posted by xmaciek82x
Well I can't take it to the dealer because this happens maybe once a week... I won't be able to simulate the problem once I'm there.
Thanks for all the ideas guys.
sounds more along the lines of your knock sensor, its normal for the evo to experience this from loud noises at the right frequency. It tricks the ECU into thinking the motor is knocking.
Old Feb 18, 2007 | 07:19 PM
3SgteGuru's Avatar
yes you are right, I got that wrong. Lol I put mass air pressure.
Old Feb 18, 2007 | 07:20 PM
Z-Ball's Avatar
uh oh mine does this sometimes too...
Old Feb 18, 2007 | 08:04 PM
binh's Avatar
Shameless plug but I'm selling a MAF from my Evo IX if you decide you need one. It has 12k miles on it. I took it out because I switched to AEM EMS. PM me if needed.
Old Feb 18, 2007 | 08:09 PM
bluebyu36's Avatar
mine did that for a while to driving me crazy.
Old Feb 18, 2007 | 09:58 PM
Evo8's Avatar
also check your BOV, if it's stock then it's known to leak
Old Feb 18, 2007 | 11:48 PM
StatixNWH's Avatar
I heard this happening to other cars with oiled filters.....the oil gets in your MAF
Old Feb 21, 2007 | 03:35 AM
ok i fix the problem
https://www.evolutionm.net/forums/sh...d.php?t=252651
the stock bov was the problem.
Old Feb 21, 2007 | 09:13 AM
xmaciek82x's Avatar
I got a IX, pretty sure it doesn't have a plastic DV.
Old Feb 21, 2007 | 12:02 PM
TeStUdO's Avatar
No it doesn't. It is metal and works great.
DONNOD
Sep 28, 2016 06:32 PM
kaj
Jul 9, 2015 01:47 PM
yellowrocket
Northwest Region
14
Apr 21, 2009 03:56 PM
blewby u
17
Oct 2, 2008 11:59 AM
VOLFLO
Mar 26, 2007 06:13 AM
