Please Post your EVO GREEN FP 20gLT dyno numbers and graphs
Old Apr 28, 2007 | 10:51 PM
  #346
Blue Evo 8's Avatar
Originally Posted by Fast Frank
Blue Evo 8- You haven't found a "monster" green there to have at it with yet Judging by your graph your going to have to play catch up against a Green-Hopefully (for you) when it happens it will be from a 40mph roll on instead of a dig or something lower-You are making slightly more power then the green but also at a higher rpm-BTW what is STD vs. SAE on your graph vs. mine? (different correction factor?)
no, not yet.....I havent found any monster Greens locally. Sure I'll race from a
40-70 MPH roll or whatever, but in any case I'll be brake boosting and taking off in the meat of my powerband. I may not have a lot of Tq. (433.XX by the way) but I'm relying on my midrange and top end power to pull me through...
STD vs SAE I dont know?
Old Apr 29, 2007 | 12:34 AM
  #347
kjewer1's Avatar
Originally Posted by Jeff_Jeske
You killed the xfer case already?
It's only two years old, and has 45k miles, but they are hard miles. Hundreds of quarter mile passes too.
Old May 3, 2007 | 01:06 AM
  #348
Tha Shocker!'s Avatar
I now have both an Invidia & SS Autochrome O2 housing as well as a 65 mm TB to go along with any porting that can be done-Going to be assembling & putting it back on the rollers this week-hoping for 500whp-we'll see how it goes-Then on the 7th going to the track w/ a bunch of the highest hp greens etc...we'll really see what happens then!
pwndkvndhsdf!!! those are some sick numbers! that's it, i'm getting a Green This is on a 8 correct? And also, your running an AEM...what hp difference would you guess using a custom reflash instead??
Old May 3, 2007 | 01:17 AM
  #349
Jspec EVO VIII's Avatar
Damn Fast Frank looking good. So guys, all my mods are in my sig including the Evogreen. I'm thinking on getting my throttle body done as well from Buschur. What do you guys think? I'm only running reflashes at the moment, don't want to run an AEM ems. I'm also looking into grabbing a different set of cams, running the HKS 280's. Thinking of some JUN 272's, i've already upgraded the valve springs/retainers. Finally, anyone running a Full Race mani? I've got the stock port/coat from Buschur, just looking if i'm going to get anymore gains from swapping them out.
Old May 3, 2007 | 03:26 AM
  #350
EVO8LTW's Avatar
Thought this might be an interesting comparison of two setups on the same dyno.
Fast Frank:
STOCK 02 housing
STOCK Exhaust manifold
STOCK UICP
STOCK TB
TYPHOON INTAKE
Run was done on C16 w/AEM @~31psi or so
His mods are AEM, AMS FMIC, AMS LICP, TBE, HKS 272/272s
vs.
Dave Buschur RS:
20G9-5 + Revolvers + ported head + kitchen sink
First, Fast Frank:
vs. 20G-9 equipped Buschur RS
(look at lower curve)
Both are on Switzer's Dynojet.
Old May 3, 2007 | 07:35 AM
  #351
Soon2BEVO's Avatar
My car is being tuned tomorrow ... no dyno though, sorry guys! This is of course granted nothing else comes my way that delays me. Dont know if thats possible though since Ive had just about every set back in the book happen that humanly possible.
Old May 3, 2007 | 08:42 AM
  #352
El.BlueEvo9's Avatar
Originally Posted by 04AWDTURBOEVO
, there are a couple of other monster 20GLT Greens roaming around.
Then mine would be a little beast.LOL
Old May 3, 2007 | 08:57 AM
  #353
Fast Frank's Avatar
Fast Frank:
vs.
Dave Buschur RS:
First, Fast Frank:
Seems a little strange
460 vs 462 whp? How does a 20g-9 make 530 ft lbs??
Old May 3, 2007 | 09:04 AM
  #354
Fast Frank's Avatar
I'll get into a lengthly post soon about my findings in maxxing out the green, max boost & all of my additional mods (65 mm TB ported intake,ported exhaust,2 different O2's,different intake pipe & air cleaner etc,...)
Let's just say so far I'm not impressed w/ any of those additional pieces & wouldn't have bothered wasting the time & $ for such a small gain-
I have the green totally maxed out & that may be why I'm not getting hardly any additional gains
FP needs to come out w/ the next version w/ a bigger compressor wheel (wishful thinking?)
Yes AEM EMS it will give you 20+ (more like 25-30 at my power level) over a reflash
Don't use Jun's (friend of mine has the EXACT setup as mine but w/ Jun 272's & he is NOT happy) 280's are just ok, but the best results w/ the green have been w/ 272's (HKS,GSC,Cosi's)
Old May 3, 2007 | 09:12 AM
  #355
Soon2BEVO's Avatar
He had a ported manifold, Ebay 02. You didnt.
He had built block with no balance shafts, PORTED head, more aggressive cams.
Probably more boost, more aggressive tune. Remember, he made the most power EVER out of that turbo than anyone else.
Old May 3, 2007 | 09:14 AM
  #356
thatguy's Avatar
Tom,
Whose going to get you tuned? What are your impressions of the turbo so far? How is the meth kit?
Old May 3, 2007 | 09:22 AM
  #357
Soon2BEVO's Avatar
Thus far I love the thing. Spools so similar to stock and it feels great. Meth kit is installed and working. Sean Ivey is doing the tune.
Old May 3, 2007 | 09:23 AM
  #358
Fast Frank's Avatar
I'm not trying to be argumentative, but, More boost? impossible I'm making 35 lbs-Did 36 yesterday & that is ALL a green will make
I'll buy the hp, but not another 70 ft lbs of torque (unless it was a 2.3 )
Old May 3, 2007 | 09:35 AM
  #359
mike 99gsx's Avatar
You're also comparing one SAE corrected graph to an uncorrected one.
Old May 3, 2007 | 12:15 PM
  #360
High_PSI's Avatar
WOW lemy see your car when your done!!! I'll check it out Friday night!
