Please Post your EVO GREEN FP 20gLT dyno numbers and graphs
^ you know, there are so many people saying how this turbo will run out of breath on a 2.3, but damn, this turbo can make power!
yeah, it will give up peak power on pump or the juice, but it will kill anyother turbo below peak power when it comes a daily driver.
Guys, here is FAST FRANK's dyno of FP GREEN:
Listen to this. He is on:
STOCK 02 housing
STOCK Exhaust manifold
STOCK UICP
STOCK TB
TYPHOON INTAKE
Run was done on C16 w/AEM @~31psi or so
His mods are AEM, AMS FMIC, AMS LICP, TBE, HKS 272/272s
This excites me.
__________________
Aby, You might be interested in Fast Frank set up.
STOCK 02 housing
STOCK UICP
STOCK TB
TYPHOON INTAKE
This excites me.
__________________
STOCK 02 housing
STOCK UICP
STOCK TB
TYPHOON INTAKE
This excites me.
__________________
I dont know about C16, but this is my chart on 93+meth and 29 PSI...and on a hot day... since then I've done some weight reduction, and added a few go faster bits to the car. I want to get retuned again and crank up the boost to like 32-33 PSI
and see if there's more power to be found.
Now I'm guessing I'm slightly over 500 AWHP....only the dyno can confirm this
Dadriva-Thanks! You too huh? Got the PM
Mr. Birdie-I'm sure you can make at leat 33lbs! Good luck & keep us "posted"
04AWDTURBOEVO-Who could you be referring to?
Nice #'s
Blue Evo 8- You haven't found a "monster" green there to have at it with yet
Judging by your graph your going to have to play catch up against a Green-Hopefully (for you) when it happens it will be from a 40mph roll on instead of a dig or something lower-You are making slightly more power then the green but also at a higher rpm-BTW what is STD vs. SAE on your graph vs. mine? (different correction factor?)
Nice #'s Blue Evo 8- You haven't found a "monster" green there to have at it with yet
