Please Post your EVO GREEN FP 20gLT dyno numbers and graphs
Old Mar 25, 2007 | 09:51 AM
  #181
trinydex's Avatar
^ hahaha you gonna move to norcal? i did... haha
Old Mar 25, 2007 | 10:57 AM
  #182
Erik@MIL.SPEC's Avatar
Davy,
You moved to NorCal? I love NorCal, but SoCal is more my speed
Now, where does UPS say my Green is right now? It left Mesquite, Texas @ 1:35am on 3/23
Old Mar 25, 2007 | 09:02 PM
  #183
DANRR05's Avatar
Originally Posted by atlvalet
I know that Bryan liked the turbo. I meant why did he think it was knock prone?
1)knock from the down pipe, ruled that out with a hammer adjustment , I data logged and it still had 2-3 knocks early in 4-5 k rpm range.
2) couldn't richen it up, possible fuel delivery problem, need to check fuel pressure, gauge on order.
Old Mar 25, 2007 | 09:19 PM
  #184
JohnBradley's Avatar
Did you use the install kit when you put in the pump?
Old Apr 3, 2007 | 06:14 PM
  #185
DANRR05's Avatar
No, I was under the impression that it is a new filter, my car only had 4 k miles on it, fuel pressure test normal after all.
Old Apr 3, 2007 | 06:22 PM
  #186
It has a different washer in the install kit that if not used causes flow issues at higher rpm. I know of at least 2 locals that had similar issues with fuel delivery and neither had used the install kit. They put it in and WHAMMO the problem was gone.
Old Apr 3, 2007 | 07:41 PM
  #187
Dr. SS's Avatar
question:
ive been reading alot about this turbo and im 99% its my next mod.
can i run this turbo with a stock ecu (flashed), and are larger injectors over stock absolutely necessary?
my supportin mods are in my sig, are there any other major supporting mods that are absolutely critical to run this turbo?
how much power would it make? (guesstimate)
Old Apr 3, 2007 | 09:20 PM
  #188
mudduck's Avatar
1) Yes, you can run it on the stock ECU
2) Yes, most (including Buschur) recommend larger injectors (~750cc)
3) You have pretty much all the necessary supporting mods (an upgraded FMIC would be perhaps the only thing to look into)
4) Your current whp + about 40
Old Apr 4, 2007 | 09:48 AM
  #189
Fast Frank's Avatar
462/464 on Switzer's dyno (Dynojet)
C-16, HKS 272's, AMS FMIC & piping,AEM EMS,1000 injectors
I sure wish there were some 50 trims around here
Old Apr 4, 2007 | 10:26 AM
  #190
Blue Evo 8's Avatar
how much boost?
Old Apr 4, 2007 | 12:04 PM
  #191
Fast Frank's Avatar
a little over 30 psi
Stock throttle body & o2 housing-Looks like a have another 8-15 hiding in there
Old Apr 4, 2007 | 12:41 PM
  #192
MR. Birdie's Avatar
post the graph. That is insane torque my friend. Good job! This is on a 20G?
Old Apr 4, 2007 | 12:45 PM
  #193
gaulrich2003's Avatar
What are you referring to when you say built motor?
Old Apr 4, 2007 | 01:06 PM
  #194
Soon2BEVO's Avatar
STOCK 02 HOUSING
Old Apr 4, 2007 | 01:24 PM
  #195
mudduck's Avatar
Nice numbers!
I think somebody is selling an Ebay O2 housing in the classifieds for like $70... Pretty sure if you still have the stocker on, you would stand to pick up 12-15whp/tq and possibly better spool with the O2 housing alone...
That would come out to be $5 per whp!!!
