Please Post your EVO GREEN FP 20gLT dyno numbers and graphs
Im noticing most people on this Turbo are going to larger injectors. Do you guys feel this is a critical point for larger injectors? Meaning, if one were to get this turbo, you will need the larger injectors? I am curious as to the air volume difference between the stock Evo 8 turbo and this 20g.
Youre absolutley going to need larger injectors for this turbo. Most people with full bolt-ons on the stock turbo can be in the 90% duty cycle on the stock turbo, however most people really come to the limit of them, and then most add alcohol injection which will lessen the amount of injector you need.
However, with this turbo, 660s would be absolutely mandatory if not in the 7s. I got a pair of 750cc since they will work fine with the stock ECU and they were the same price.
Hey, a question for anyone that is already running this turbo. Did you notice more of a "whistling" sound upon spoolup? I've had mine in for about two weeks, still untuned so I can't really get on it yet, but it definitely sounds different than the stock IX turbo..
Anyone want to comment on theirs?
Thanks,
Tony
Thanks,
Tony
(anxiously awaiting everyone's FP Green results...
tcarretti, please be sure to post up your impressions of the Green as compared to your IX turbo (spool, top end, etc) ... as well as what IX cams you went with and why. Thanks
)tcarretti, please be sure to post up your impressions of the Green as compared to your IX turbo (spool, top end, etc) ... as well as what IX cams you went with and why. Thanks
blockhed, are you getting your race gas tune this Wednesday? We're all pulling for you (to take down some 50 trims...
Also, please keep us updated on your pump gas runs
Fow what it's worth, the same math puts the stock injectors on the stock turbo at 99.7%, and I logged values between 99 and 101 regularly.
