Please Post your EVO GREEN FP 20gLT dyno numbers and graphs
Old Mar 2, 2007 | 03:40 AM
  #91
EvoLutionized8's Avatar
04AWDTURBOEVO
Needed to ask why you recommend -4/-1 settings for your cam gear settings? I saw an earlier post on this thread recommending anywhere from +3/-3 to +1/-3, which obviously states forwarding timing up front and retarding in the end. I was just wondering why you may think this is best.. I hope to get close to your numbers and want to be set-up as close as possible when my green turbo arrives.. thanks in advance.. Mike
Old Mar 2, 2007 | 04:07 AM
  #92
EVO8LTW's Avatar
Originally Posted by 04AWDTURBOEVO
[ I want to add, my current gear settings are way different, but I do recommend -4/-1 for most applications]
Does TTP "sell" those settings?
Old Mar 2, 2007 | 08:23 AM
  #93
sparky's Avatar
Post
....[..... my current gear settings are way different, but I do recommend -4/-1 for most applications]
Is the -4,-1 setting mostly for optimal dyno numbers and drag racing. Are your current cam settings preferable for everyday drivability and torque? I was just curious what you are currently using as cam timing settings.
Old Mar 2, 2007 | 09:00 AM
  #94
gkania's Avatar
Retarding the cams shifts the power further up the rpm range. You lose response and gain top end.
Old Mar 2, 2007 | 10:10 AM
  #95
EVO8LTW's Avatar
There's more than up and down though. There's also the shape of the powerband. I'm guessing that TTP's settings involve retarding the intake cam but retarding the exhaust cam even more to narrow and boost the powerband by shrinking the lobe separation angle (the reverse of what -4/-1 does). That would make for a mean cam lope on even small cams.
04AWDTURBOEVO, am I getting warm?
Old Mar 2, 2007 | 04:12 PM
  #96
JMB8606's Avatar
ordered my green today. maybe the first one with a 2.3 and dyno numbers
Old Mar 2, 2007 | 06:11 PM
  #97
scorke's Avatar
Keep me and us posted very interested.
Scorke
Old Mar 2, 2007 | 11:03 PM
  #98
04AWDTURBOEVO's Avatar
-4/-1 cam gear settings is very neutral for most cam applications. It will give you a decent spool up, good mid range power and nice top end hp, also good peak Tq. numbers. At least that is what I have experienced personally. I have seen several other local Evos doing good with this combination.
I have a smaller intake cam and a larger exhaust cam, but they are a mild combination.
gkania also happens to run the same cam gear combination I am using now, exactly the same and he has 280/280 cams. There are about 8-9 of us using the TTP settings locally, from 264/264 cams to 272/272's to 280/280's. Even 280's Comp cams and we all have gained mph. About 5 of them run 11's at 117 plus on the stock turbo. I know just talking about this here could start another debate and I really don't want that to happen to the thread.
I can say that our intake cam setting is retarded more than the exhaust side. -4/-1 is a good start. You can retard more on the dyno or at the track if you want where you can see the results. There is your clue, . It has been near a year that Scott set my gears this way, and I won't touch them again. I am very greatfull he set them this way for me. He did not have to do that for any of us. So we are glad and run well with them.
Old Mar 3, 2007 | 02:46 AM
  #99
Thanks for your answer.. I'll be doing my own R&D with my cam gears set w/ the -4/-1 and go from there.. +1 above.. also I wanted to ask aobut your Forge WGA.. Did you have to do some fabrication to it to fit your 20G9LT?? thanks again 4wdturboevo
Old Mar 3, 2007 | 07:43 AM
  #100
CBRD's Avatar
it would be nice if we could ever get a turbo,
our client has been waiting 1.5 months
cb
Old Mar 3, 2007 | 11:17 AM
  #101
EVOlutionary's Avatar
Originally Posted by RSX
guys,
forgive the intrusion but I am one of the few UK people to be running an evogreen and would appreciate some feedback.
The car is an 03 UK evo 8. It is not an MR spec, so has standard evo 8 cams.
so far the most I have had out of the turbo is 315whp on dyno dynamics rollers, (which read around the mustang level).
The 10.5 evo 8 turbo I had on before made 295whp. I don't know if it would have made more because the evogreen was stuck at this same power until we reversed the dump valve to find the additional 20whp.
I see a lot of people on here getting great results changing for big cams on normal turbos, but I see no examples of big turbos on standard cams which are subsequently changed.
Anyway, all I want to know is, do people here think the standard evo 8 cams are the limiting factor as to why I am only seeing 315whp on straight 93/94 pump fuel?
I have spent a lot of money buying some new cams to see if it will solve the problem, but am not sure that I was on the limit of the standard cams before.
new cams are 265 degree custom piper items. 226 and 220 degrees at 1mm lift and 11.5mm and 10.8mm peak lift. Hope they work out.
Any thoughts would be greatly appreciated.
Adam
I read your post on LancerRegister, I believe. I've been watching over there to see what type of success you lads have with the EVOGreen.
I would say that in the USA, a vast majority of people upgrade cams before we start messing with upgrading turbos. I am sure there are a few out there, but I can't recall ever seeing a post of anyone running stock cams with any 50trim or larger turbo.
Depending on your cam choice, from mild to wild, I think you can expect to see anywhere from 20-45whp improvement. I believe I also suggested to you a ported stock exhaust manifold, as well as a tubular 02 housing (turbo dump elbow). Regardless of what people on LancerRegister believe, those will give you another 15-30whp. So you stand to gain 35-75whp (most likely around 45-50) with 3 simple upgrades. . .
Good luck mate.
EVOlutionary
aka "AutoXEvo" on LancerRegister
p.s. - if you are not already using it, I would suggest you get a metal "JDM EVO MR" BOV (same as USA EVO9 BOV). It will hold alot more boost than the plastic ones that came on EVO VIII's.
Old Mar 3, 2007 | 06:17 PM
  #102
Originally, I purchased my 20G-LT with the 18 psi stronger actuator.
I decided to try the new Forge IX red spring actuator. The newer actuator is a piston design that it is say'd to be more reliable and with improved operation.
It bolts right on to the 20G, just like the stock actuator. No modifications neded to use it. I was using the old Forge VIII type actuator on my stock turbo and I liked it very much. They come chrome'd and perform as prommised. So I got it and set the pre load spring to about 19.7 psi. It holds there.
Old Mar 4, 2007 | 02:28 PM
  #103
FastAzzEvo's Avatar
log please of a 19.7 hold in 3rd gear from 3000-7800
Then i'll believe
Old Mar 4, 2007 | 02:45 PM
  #104
High_PSI's Avatar
Yeah the issue is the spikes. I would love 19.7 psi solid but i'll spike to over 25PSI on the spoolup, which would cause knock for pump gas users.
Old Mar 4, 2007 | 03:38 PM
  #105
derangedazn's Avatar
very interesting thread....looking forward to my 20glt set up
