Please Post your EVO GREEN FP 20gLT dyno numbers and graphs
Old Mar 4, 2007 | 06:24 PM
  #106
04AWDTURBOEVO's Avatar
Originally Posted by FastAzzEvo
log please of a 19.7 hold in 3rd gear from 3000-7800
Then i'll believe
^^ What a joke!
So I got it and set the pre load spring to about 19.7 psi. It holds there.
__________________
--->>> This is what I sayed on my previous post.
This ^^^ means I set the WGA spring to 19 psi and boost does not go pass that on the red WGA spring alone.
Where in my post did I say it can hold 19.7 psi in 3rd. gear from 3000 to 7800 rpms? Where does this come from, my man?
I think you may need in reading lessons!
If you have been following the 20G-LT reviews, then you would know that because it has a larger turbine wheel, it spools a little later, thus you will never see one hiting 19.7 psi at 3000 rpms. Are you ok.?
If you want to believe it, then buy yourself a 20G-LT and log it all you want . I really don't care if you go around all your life wondering about this!
Old Mar 4, 2007 | 06:34 PM
  #107
Faust's Avatar
I think he is referring to the above statement to where you DID say: IT HOLDS AT 19.7 PSI.
Dude, you really need to chill the Hell out. You totally went over the edge with this one. Calm down and count to ten!
And before you start telling someone they need help reading, why don't you learn to eloquently explain your thoughts.
Old Mar 4, 2007 | 06:40 PM
  #108
scorke's Avatar
There is a huge difference between explaining his thoughts thoroughly, and not stating something at all..... He never said what has been in question, I don't understand this...
Scorke
Old Mar 4, 2007 | 06:52 PM
  #109
Faust's Avatar
Scorke
I may be misunderstanding something then...I quoted exactly where he said that it holds at 19.7 psi. And 3 other members (including myself) interpreted what he said the same exact way...Now one member made a statement about it holding at 3000 rpms but I understood what that member was trying to say overall. Please correct me if I am wrong.
And instead of just explaining what he meant he flips out about it?!? Sorry for our apparent confusion
Old Mar 4, 2007 | 06:57 PM
  #110
dsmfan95's Avatar
Then i'll believe
I'm holding 22psi from ~3500-8000 on stock turbo with stock actuator. Not rocket science, isn't that right 04AWDTURBOEVO
Old Mar 4, 2007 | 07:29 PM
  #111
Thanks skorke, .
And Faust, I did not flip. If you read all my post in this thread, I have contributed alot of good information. This FastAzzEvo guy comers in here twisting words around and starting trouble and says nothing about the 20GLT and related dyno graphs.
Hey dsmfan95, I told you, not rocket Science at all . Here is a log of my old stock Evo VIII 9.8 turbo. By the way, it was using a Forge VIII WGA, .
I think I will go out tomorrow and make a log of the 20GLT. I got C16 in there and the boost is set at 32 psi until the gas runs out, .
Attached Thumbnails Please Post your EVO GREEN FP 20gLT dyno numbers and graphs-qqqqqqqqq.jpg
Old Mar 4, 2007 | 07:39 PM
  #112
Faust's Avatar
Hey Bro, I can totally understand and appreciate what you are doing with this thread. I was just trying to point out where he may have mis-understood you. I too am getting this EvoGreen and am just as excited as you are about it. Thanks and good luck.
Old Mar 4, 2007 | 08:39 PM
  #113
El.BlueEvo9's Avatar
Got mine. It's simple really. It full spools very quickly, and I've been pulling away from everyone I've ran into so far . By the way, my signature on the bottom there was with the stock turbo. I know I know, it's slow. But I'm much faster now with the LT
Old Mar 4, 2007 | 08:50 PM
  #114
ihatepotholes's Avatar
how much more power can you put down with LT than 9's stock turbo? assuming same boost on straight pump, no alky/meth or race gas
Old Mar 4, 2007 | 09:13 PM
  #115
FastAzzEvo's Avatar
^^ What a joke!
__________________
I didn't mean to twist your panties. I mean damn get the sand out.
You said hold 19.7. I asked for a log because I don't know anyone with 20g or stock turbo holding that kind of boost.
I just want to have correct information for myself and others that may read this thread.
Old Mar 5, 2007 | 04:30 AM
  #116
EVO8LTW's Avatar
I don't think holding 19.7 at redline is that atypical. I have a WR turbo (basically a 20G-8 with a 5-blade wheel) and it easily sustains that much boost at redline.
Old Mar 5, 2007 | 07:33 AM
  #117
dsmfan95's Avatar
With a good boost controller a lot more can be held than 20psi.
Old Mar 5, 2007 | 07:39 PM
  #118
kjewer1's Avatar
Mine holds 26 psi to redline (8k) on the street (~23-24 on the dyno) with the FP upgraded actuator and a Joe P MBC, for reference. I thought this was pretty much made common knowledge a couple months back, but my thread hasn't seen any action in a long time I guess.
Old Mar 5, 2007 | 07:47 PM
  #119
FastAzzEvo's Avatar
can we see data logs of this boost?
Old Mar 5, 2007 | 09:19 PM
  #120
kjewer1's Avatar
There are already DSMlink datalogs posted in the 20gLT airflow thread, so I'm assuming you want AEM logs now? I have those too.
