Please Post your EVO GREEN FP 20gLT dyno numbers and graphs
Old Apr 6, 2007 | 10:47 PM
  #256
sparky's Avatar
I know that this is a dumb question, but I have my doubts, so here goes: Is the 20G-LT/EvoGreen actually consistently producing better torque numbers on pumpgas than the other stock and stock-based turbos such as TME, 20G-9-5, White Rabbit and etc.? I just have some doubts, as I've seen some dyno numbers where a stock turbo produced pretty impressive torque numbers while I've seen some cases where the Green produces what I thought were relatively low torque #'s.
Old Apr 6, 2007 | 11:47 PM
  #257
Erik@MIL.SPEC's Avatar
The bigger turbos tend to produce lower peak torque numbers on pump gas, but if you look at the graphs, the EvoGreen holds torque longer and flater than the stock turbos.
Old Apr 7, 2007 | 05:19 AM
  #258
Blue Evo 8's Avatar
Originally Posted by EVO MR 28
I got my car up, running and tuned today. To cut the time short I put down 312whp and 285 torque on a mustang dyno which reads roughly 20% lower than other mustang dyno's. I am really pleased with the numbers and I will get my graph up tomorrow.
how much boost? what kinda gas...?
Old Apr 7, 2007 | 07:03 AM
  #259
sparky's Avatar
O.K., thanks! The Green has a broader, flatter torque band than the stock 16G's do then. Since it spools slower than a stock 16G then I guess that lowend torque wouldn't be as good. I installed mine, I just haven't had a chance to drive the car yet.
Old Apr 7, 2007 | 12:11 PM
  #260
EVO MR 28's Avatar
whoops forgot about that, 24psi on 91
Old Apr 7, 2007 | 12:54 PM
  #261
MR. Birdie's Avatar
Damn how are you able to turn it up to 24psi? Mine was set at 22psi on 91.
Old Apr 7, 2007 | 12:57 PM
  #262
EVO MR 28's Avatar
I have my boost controller turned all the way down, we tried to get it to lower but it just wouldn't. It's pretty high I know but...
Old Apr 7, 2007 | 01:06 PM
  #263
SuPeRNeT's Avatar
Some Cams would really wake your car up...
Old Apr 7, 2007 | 01:26 PM
  #264
Blue Evo 8's Avatar
what kinda boost gauge are you using?
Old Apr 7, 2007 | 01:28 PM
  #265
EVO MR 28's Avatar
Here is my graph, I am actually really pleased with these numbers, the dyno that I did this on reads about 20% lower than other mustang dyno's.
Old Apr 7, 2007 | 01:29 PM
  #266
EVO MR 28's Avatar
Defi
Old Apr 7, 2007 | 01:34 PM
  #267
EVO MR 28's Avatar
Yea and I will def. do cams once I get the money, I think that these numbers are pretty good for having no cams, tuner said that on a dynojet I would be around 385 but comparing dyno's isn't ever really fair. What do you guys think?
Old Apr 7, 2007 | 01:40 PM
  #268
SuPeRNeT's Avatar
what was your base line?
Old Apr 7, 2007 | 02:24 PM
  #269
Blue Evo 8's Avatar
Defi
Those gauges can read a bit off...
Old Apr 7, 2007 | 02:41 PM
  #270
EVO MR 28's Avatar
We didn't do a baseline but a couple weeks ago I did a tune on a dynapack with the intake, fmic, mbc and that was 325.7whp with 310 ft/lb
