Help with bad cylinder!!
I have a problem with my #2 cylinder. I am getting oil all over the spark plug.
The funny thing is, I did a compression check and get about 160 on all cylinders. Also the car runs fine, it does not seem like there is anything wrong with it.
The only reason I found this was because I changed my plugs. So what could be the problem? I was thinking maybe a cracked piston or bad rings? If it was that the car would run really bad right? It runs great. Could it be a bad intake valve not seating correctly? The car only has 38,000 on it.
No notice in power loss until the plug finally fouls out due to oil seapage. Then you'll start to misfire.
If your oil rings are bad and your compression rings(piston rings) are good, you will still have good compression.
and they always say to pour a capful of oil into a low cylinder when testing and if the compression goes up, it's the rings, so the oil in the cylinder is probrably helping to keep the compression higher.
so lets sum it up.
oil on plugs and around the plug threads
compression is 160 on all cylinders (oil in the cylinder is keeping it up)
using a about 1/2 qt 1000 miles.
You number two cylinder my be scoured or it is indeed the piston rings going bad or at least the ring on that cylinder.
Is it smoking dark soot? Are you getting dark sooty substance on back of bumper or tailpipe?
Get another compression checker and check the compression on all cylinders again.
If its more than 10psi off you are goign to start having problems soon.
What your mods........
Leak down test is what you need to do. By the way my car burns oil also but even in the owners manual it says it is normal for our cars to burn some oil. But a 1/2 quart ever 1,000miles seems much.
Tey not to rulle out a faulty valve stem seal.... I see where you are going with the oil ring going bad, but even a slight scratch on a cylcinder wall can noticeably efftect compression. If compression is holding steady, I would lean more towards the cyl head valve stem seal, OR even a worn/burnt oil passageway on the head gasket. FWIW...
so lets sum it up.
My mods are cams ,exhaust, MBC, tune.
