Race Gas
Old Mar 9, 2007 | 01:25 PM
  #61
mudduck's Avatar
Originally Posted by evoIX15
i fill my car with 93 everytime i fill up...is that bad?
Something tells me you're not the only one...
Old Mar 9, 2007 | 01:52 PM
  #62
evoIX15's Avatar
I said...I fill my car up with 93 octane everytime i put gas in it...most of you are talking about using 91, i was wondering if there was something wrong with 93?
Old Mar 9, 2007 | 02:06 PM
  #63
Warrtalon's Avatar
That's because half the country or more can't get anything higher than 91. We'd all use 93 if we could. You didn't know that some places only get 91 and that you should use the highest possible octane?
Old Mar 9, 2007 | 02:19 PM
  #64
mudduck's Avatar
Oh, ok...
Old Mar 9, 2007 | 02:21 PM
  #65
vjz225's Avatar
im knew at this how to you change from one map to the other?
Old Mar 9, 2007 | 02:26 PM
  #66
Warrtalon's Avatar
By using EcuFlash, which is free flashing software, a laptop, and the Tactrix flashing cable. Head to the EcuFlash sub-forum in the tuning section to read the tutorial. To switch maps also requires having separate maps that have been tuned.
Old Mar 9, 2007 | 02:30 PM
  #67
vjz225's Avatar
thanks
Old Mar 9, 2007 | 02:45 PM
  #68
Ralph's Avatar
I plan on running a 50/50 mix of 110/91 every weekend.. say 4-5 gallons each. I hope to have my o2 sensor's still last a while like War's and some other guys' have reported. (see: Years with no problems)
Old Mar 9, 2007 | 05:35 PM
  #69
MR. Birdie's Avatar
Is there a place to buy the cable for ECUFLASH? also would it be more safe to run on straight 100 then 91 + meth or alky?
Old Mar 9, 2007 | 05:51 PM
  #70
nj1266's Avatar
Here http://www.tactrix.com/product_info....e4cc5eb447d8d5
Old Mar 9, 2007 | 05:55 PM
  #71
housedj's Avatar
Thumbs up
i have exclusively used racegas in my '03 since feb '05. When i had gotten my Dynoflash Al tuned it for the 101octane available in Chandler, AZ. Once i got the Mynes flash, i switched gas to Sunoco GT+ 104 which is what their shop carries. i do not & will not use pump gas & like i always say " $8/gallon is cheaper than a new motor!!!"
performance ain't cheap so u gotta pay 2 play...
Old Mar 9, 2007 | 05:56 PM
  #72
Sharkbite2000's Avatar
Ah, you're confused, because not all race gas is the same. There is unleaded race gas, which is just a higher octane version of what you get at the pump, and there is leaded race gas, which is much different. The unleaded octanes are usually seen as 98/100/104 while leaded is usually 110/112/116. Race gas doesn't hurt injectors, but the leaded race gas does eventually foul out the o2 sensor and destroys the cat if you have one. Unleaded gas doesn't harm anything and has no disadvantage.
It's unlikely to find 110 "at the pump," because it's illegal for street use, so they usually make you pump it into a container in order to buy it. If they let you pump leaded race gas into the car, then they would get shutdown by the fire marshal.
They got straight 110 Octane from the pump in west palm beach in the sunoco.
Old Mar 9, 2007 | 06:09 PM
  #73
housedj's Avatar
Originally Posted by Nez136
I found out form the last time i visited the strip that i have to change them more often than 3k miles otherwise i have misfire above 27psi.
u know i was having this exact same problem but i figured that it was the stock ignition system not being able to keep up with the added boost since my current flash spikes to 27PSI & falls to 23 by redline (7800rpm). then i changed plugs & ran 30PSI for a month. backed it down to 27 since there was no measurable gain for me on the stock turbo. i currently change my oil every 2k miles (same time i change tires since i run advan a032R's) & i now change plugs every 4k miles...
Old Mar 9, 2007 | 06:44 PM
  #74
MR. Birdie's Avatar
hey thanx nj! do you know what the white plug go? I know the black one go to your OBD 2 port.
Old Mar 9, 2007 | 07:31 PM
  #75
Warrtalon's Avatar
If it's leaded 110, and I haven't yet heard of unleaded 110, then it's illegal to pump it straight into the vehicle.
Mr. Birdie, read the tutorial, man. This is all simple, basic stuff that you can find right above this forum in the EcuFlash forum. The white plug goes in the white receptacle next to the OBD-II port.
Yes, straight 100 on a daily basis would be safer than 91 + alky.
