Anyone using JAMM lifters??
Old Mar 13, 2007 | 05:28 PM
jrsimon27's Avatar
what did they refer to pieces of aluminum on both ends?
Old Mar 13, 2007 | 05:29 PM
evo542's Avatar
might as well get solid lifters if you want quiet&better performance
Old Mar 13, 2007 | 05:36 PM
Ted B's Avatar
Solid lifters are noisier than hydraulics.
Old Mar 13, 2007 | 05:47 PM
Soon2BEVO's Avatar
So you dont damage the lifters while compressing them.
I ended up taking them to Alex at DogboxRacing who works on DSMs/EVOs and I asked him about them and he said he had bled them before a hundred times, so I let him do them, so Im sure they are OK. I did not want to mess with doing that and risk messing something up only to have to take them out again. F that!~
Old Mar 13, 2007 | 05:48 PM
jrsimon27's Avatar
so do you have a ticking noise in your engine that you decided to buy this jamm lifters?
Old Mar 13, 2007 | 05:52 PM
Soon2BEVO's Avatar
Comeon man, of course! The tapping wasnt THAT bad, but it annoyed me. I had the cams out to do timing belt and such, so I said, this would be good time to do the non tick lifters.
Old Mar 13, 2007 | 05:59 PM
dan l's Avatar
If they are that cheap they are not OEM meaning their is a good chance they are top line units. Makes sense because top lines retail at 130 so JAM is adding their markup so 160 it is. They come with machining oil all over them. I forgot if I bled them or not but I remember a huge racket when I first fired it with them. Then they filled with oil in 10 mins and all was fine. They have been in my car for about 4 years now (the top line ones).
Old Mar 13, 2007 | 06:04 PM
Paul Nelson's Avatar
Ive got the JAM lifters and have had good luck with them
Old Mar 13, 2007 | 06:37 PM
jrsimon27's Avatar
did you bleed the lifters when you installed them?
Old Mar 13, 2007 | 06:41 PM
evo542's Avatar
i don't know about that, from my experience the solid ones are completly quiet. For example on my friends 05 spec v you cannot hear them at all the gap is only .007in not much slack. If the solid lifters are making noise they're out of adjustment for sure, there's too much clearance between cam centerline and lifter itself
Old Mar 13, 2007 | 06:53 PM
jrsimon27's Avatar
yeah but why buy solid lifters which need to be calibrated every other mile??
its better the hydraulic ones you dont need to be calibrating nothing
Old Mar 13, 2007 | 07:40 PM
Ted B's Avatar
Maybe, but that's not my experience, FWIW. One reason why hydraulics exist in the first place is because they are (or should be) quiet.
And about the noise, conversely, if there is no noise with solids, the clearances may be too tight. One doesn't know these things until/unless he checks them HOT. If any are too tight (especially the exhaust valves), that tends to wipe out cam lobes quickly.
I'm not saying this is the case, but it's something of which one should be aware if he contemplates using solid tappets.
Old Mar 14, 2007 | 05:38 AM
jrsimon27's Avatar
bump
Old Mar 15, 2007 | 06:11 AM
jhanksevo's Avatar
so this is a good option to stop the ticking
bryonboals
Jan 17, 2017 04:29 PM
4ukc
Sep 2, 2016 12:20 AM
Lexus01IS
13
Mar 13, 2013 10:42 AM
ilikeppie
26
May 31, 2012 01:52 PM
Noogles
Feb 15, 2008 11:17 PM
