Getting ready to install cams.
Old Mar 18, 2007 | 12:16 AM
s10v8's Avatar
Ok so i had a few questions about a cam install. first off, i plan on running staggerd. 272 264. just maing sure that you must run a 272 intake and a 264 exhaust?
question 2. will i need new valve springs?
any help is appreciated.
Old Mar 18, 2007 | 12:29 AM
chaotichoax's Avatar
it is definitely a good idea to run new valve springs and retainer with meth or higher boost levels
stock boost you can get away without them but it's still a good idea
as for the staggered setup I don't know
Old Mar 18, 2007 | 12:41 AM
Aby@MIL.SPEC's Avatar
stock springs are fine w/hks, gsc & buddy club cams.
Old Mar 18, 2007 | 12:46 AM
s10v8's Avatar
ok thanks guys. als, will i run the 272 on the intake side or exhaust side? if im running staggerd
Old Mar 18, 2007 | 12:49 AM
^ depends on what cams you have. as the intake & exhaust cam are not interchangable.
Old Mar 18, 2007 | 01:10 AM
s10v8's Avatar
I know that. I have a set or 264/264 from hks. but i was curious if it is better to run 272/264's or should i stick with just 264/264.
Old Mar 18, 2007 | 02:29 AM
EVO8URV8's Avatar
272/272 like mine will do
Old Mar 18, 2007 | 07:50 AM
Dead-Man Inc's Avatar
272s or 280s for best results ! ..
264 = Low end power
272 = Mid Range
280 = Top end
all of the HKS are ok with the Stock Valve springs and retainers !
Old Mar 18, 2007 | 08:08 AM
Jakeg97's Avatar
i dont know if its better , but people have run with it.
Old Mar 18, 2007 | 10:16 AM
Buksh's Avatar
What would be the best option for low and mid end
Old Mar 18, 2007 | 10:23 AM
Mitchubishievo's Avatar
264/272 is beastly....my friend runs it in his Evo and it felt just as fast as my previous Evo 8 with 272's.
Silk's Avatar
I run a staggered GSC 272/264 and really like them. Very responsive power curve
Old Mar 18, 2007 | 11:01 AM
s10v8's Avatar
Thanks guys.
Old Mar 18, 2007 | 11:12 AM
4WS Tuning's Avatar
you dont need them based on boost, you need them depending how aggresive the cam is... hks and gsc and mild cams... even their 280's aren't as aggresive as the jun 272, revolver, etc....
another example.... for the evo ix the gsc s1 doesn't require new valvetrain, but the cosworth does because its more aggressive....
cheers!
Old Mar 18, 2007 | 11:14 AM
saywhen's Avatar
Thumbs up
264/272
EclipseMblue
Jun 7, 2008 02:30 AM
s10v8
Nov 4, 2007 03:52 PM
Turd Squirter
Apr 20, 2006 11:45 PM
SilverMr
Jun 30, 2005 06:09 PM
Bonefish
Jan 13, 2004 05:03 PM
