Drivetrain Fluids for IX?
Old Mar 19, 2007 | 04:23 PM
Redline-Z's Avatar
Veteran: Air Force
I need help choosing the right fluids. I have read mixed reviews but I plan to change them every 6K miles. Also The ACD fluid when does it get changed? If you have any recommendations please speak them!
TC: Diaqueen LSD or Redline?
RD: ?
MT: BG Syncroshift
Old Mar 19, 2007 | 06:17 PM
Luis@TTP's Avatar
RD: ?
MT: BG Syncroshift
the rear diff uses dia queen it will have a little white sticker that says lsd. but it uses diaqueen. the acd fluid doesnt need to be changed for the most part i have only seen two that have shown signs of slipping clutchs (internally in transfercase) but every time you open the acd line you have to bleed the system. Hint theres a trick for that. but it uses sp2 approve auto trans fluid witch you can get anywhere. i would recommend changing the fluids every 15k.
Old Mar 19, 2007 | 08:19 PM
chaotichoax's Avatar
TC: Diaqueen LSD
RD: Diaqueen LSD
MT: BG Syncroshift is popular
those are my opinions
Old Mar 19, 2007 | 08:20 PM
double post - evom is glitchy
Old Mar 20, 2007 | 09:59 AM
Redline-Z's Avatar
Veteran: Air Force
So I should run Diaqueen and not an "Upgraded Shock-proof fluid" I do drive it pretty hard so I plan to change the TC fluid every other oil change.
Old Mar 20, 2007 | 03:33 PM
DO NOT run anything but oem tc and rear diff fluid...as the majority of people that have, have had problems...it's not worth the risk and without oem fluid a dealer is likely to not warranty you either(not that they honor warranties anyway haha but yeah)
the tranny you can use whatever you'd like search and see what others use
Old Mar 20, 2007 | 03:34 PM
Danny23's Avatar
BG 2 in the trans. stock diaqueen in the t/c and diffs. PERIOD!
Old Mar 24, 2007 | 10:29 AM
Redline-Z's Avatar
Veteran: Air Force
Warranty Smorranty, Good tip though! Ill use the Diaqueen and BG!
TheBlueBlur
19
Apr 15, 2009 09:05 PM
Pure Playaer
41
Oct 17, 2008 04:21 PM
evox7
49
Jul 13, 2008 10:50 PM
SpyderTB
Apr 23, 2008 09:33 PM
holyfrickster
30
May 21, 2007 11:08 AM
