Evolink computer
Old Mar 20, 2007 | 11:33 PM
evotrak's Avatar
Evolink computer
Hi
Greetings from New Zealand
Ok so I have a JDM evo IX GT
Previously I had reflashed the computer
Following this I fitted the prototype evolink ecu
On a dyno pack we ended up with 240kw at the wheels (nz made dyno, need to remove wheels)
My car was the test car for the new link (same people that make the KnockLink) computer.
On full boost (especially lower rpms) it was a lot smoother and more power than on the factory even after flashing.
I asked why this was and was told about injector phasing ie at what point the fuel is injected compared to inlet valve opening, etc. Not that they actually tol me...although it seems i can download the map!
I would be intersted in comparing what other results people have got for a car in similar spec.
Thanks
Andrew
Old Mar 21, 2007 | 01:35 AM
andrewn's Avatar
also will put some kelford aka cosworth cams in it next to see what difference that makes, before we do we will need some bigger injectors as the current ones are maxed already
note this is a JDM GT with the mag turbo, etc
Old Mar 21, 2007 | 06:06 AM
Spooldyou's Avatar
evolink huh? Nice. I loved DSM link, theres a few guys running it in there evo's with great success.
Old Mar 21, 2007 | 11:09 AM
andrewn's Avatar
The computer is here www.linkecu.com
Interestingly Kevin Ban has driven the car and says it is better than what can be achieved with AEM.
If you are wondering who Kevin ban is...he's the guy who has just sold 300 sets of 'Cosworth' cams. he actualy designed the cams himself and he owns kelfords.
Andrew
Old Mar 21, 2007 | 11:13 AM
MRadjahoe's Avatar
Hmmm... very interesting...
Old Mar 21, 2007 | 10:30 PM
andrewn's Avatar
When i first joined this forum (was it that long ago) 2001, i had a 6 and nothing was available (from 1st hand experience) about the evo on this site (also would use my original login but can't change the email...)
Since then things have changed! which is all good.
Having relashed the factory computer...wef ound power but we found another 20kw since then.
I have run out of injector ...on the factory turboi?
Andrew
evolink
Oct 11, 2008 12:39 PM
FILTH
23
Jun 17, 2008 05:23 PM
FILTH
Jun 11, 2008 10:31 PM
Zeus
15
May 17, 2005 03:37 PM
