HKS EVC V problems?
HKS EVC V problems?
I was getting my car tuned the other day and i cant go past 24psi with my ebc. Anyone else have this problem? And what did you do if you did have this problem?
Whats that and how do you do it? I know the tuner pressed mode one and put it to 40 and mode two and put it to 40 and the warning level all the way up and it still wouldnt go past 24psi
take the vacuum line for the wastegate off the stepping motor to determine if its a boost controller setting issue. Make sure you can handle running more than 24 psi first ( race gas ). If the boost goes above 24 psi, you have a setting issue or stepping motor issue ( probably setting ).
Be careful bro. especially running meth. Dont crank up the gain and floor it. Gradually raise it. If you dont see any difference, raise it up a little more. Just be careful, boost is not forgiving.
