GT3076R so laggy ??
No also cools the intake charge signifigantly. It cools the air a TON which makes a lot more power because the denser the air the more air, also when turboing which makes the air pretty damn hot the help is even more of an increase.
To me alky and 24 psi is an injustice, alky and 25-30 psi makes sense.
Scorke
Scorke
Scorke
Scorke
I'd be pretty skeptical of those dyno number based on the fact that we are looking at an uncorrected dyno pull in February in Connecticut. Corrected numbers will most likely be lower. I just had my car dynoed at AMS - 70 degrees ambient temps - and uncorrected numbers would add more than 5 whp to my chart as opposed to SAE corrected. I'd also be skeptical of any number coming off of Pruven's dyno ... one of the most inflated AWD dynos in the country. If I was you, I'd get it dynoed somewhere else just to validate...
l8r)
I don't mean to come across as a hater, but I'm gonna have to call shenanigans on that graph.
l8r)
l8r)
also u do realize that a dynojets numbers are what they are. they can not be altered like mustangs and DD's. think about it
Not hating on you personally, just skeptical of the circumstances surrounding that graph, that's all. In the end as long as you're happy with your car that's all that matters.
l8r)
l8r)
https://www.evolutionm.net/forums/sh...d.php?t=178448
Anybody else made 480 wtq on the stock turbo?
Scorke
Scorke
Scorke
Scorke
o thats sharkebites old setup. the last dynosheet he made, (i was there for) was like 700whp and like 550tq with a fully built, modded to the gils 37r. so i dont think thats crazy numbers for a 37r on 40 psi.
put everything into perspective.
From: Work - New York, Alaska, Mexico or the Caribbean. -Home - Tx Hill Country
Nothing to say DB. The numbers are what they are and really aren't an issue.
Now, let's see if we can get back ON TOPIC. What happend with the OP's car? Have I missed it in all the side tracks?
I had actually planned on doing a 50 Trim 3076 comparison, but just don't have time and recently put on a 35R. I had the 3076 and was very happy with it. I was going to switch it out for the 50 Trim, but got a great deal on a 35R.
700 450, yeah that would be more realistic than 700 650, which is ridiculous https://www.evolutionm.net/forums/sh...ight=sharkbite .
Scorke
Scorke
maybe u can clear something up for me. ok i just saw a video of that buschur 3065 running 93 pump gas and alky with only about 24psi peak. it was making 460 ish at "the shop". so my question is, whats the alky for if he is only running 24 psi? i mean is obv doing something if its making 460whp with 24 psi, but i thought all alky did was act as a higher octane so that u could crank up that boost. enlighten me.
Scorke
Scorke
ps im done, 400whp is a ok with me and i love my ATP 3037s
