GT3076R so laggy ??
Oh and bye the way I have seen peak boost at 4200 rpm in my logs with a manual boost controller. where my friend has seen peak boost at 4000 rpm using and electronic boost controller same turbo kit , same wastegate tial 44mm!!
Here is the third gear spool of my Tuning Technologies 35R turbo kit with the AMS 2.3 stroker. 20psi by 3900rpms. Just gotta love that stoker!
(ps. In case you are wondering, the EGT gauge isn't hooked up.)
I seriously think the issue with lag is subjective ..
If you decide the time at which the rpm hits full boost is the definition of lag .. then smogrunner's 35R has not much lag at all
but if you decide the TIME while waiting for the rpm to reach that boost level ... then its really laggy as hell
Well at least that's my definition .. since between 2500rpms and 3900rpms .. I gotta wait like forever before the car comes alive
so a few pages back someone was saying the rnr kits are junk and dont make power, i have a 35r kit on my 2.3 it made good power from what ive seen, it is only tuned to 17 psi and i put down 445 whp so im sure itll make a whole lot more on pump with alky and 30psi, qnd i see full bost around 4200 i think
I never got them from Top Speed. When I was running a 2.0 and 3076 as I mentioned before I had a ridiculous exhaust leak where my exhaust manifold wasn't completely on, luckily my dealer noticed it while reassembling my motor and now it is all sorted, in fact the 3076R kit is sold.
On a 2.0 I made the exact same peak power and 40 less peak ft lbs of tq.
Basically with a horrible exhaust leak my car made the same tq as yours. With the exhaust leak fixed and a stroker it made about 45wtq more at peak
Scorke
Scorke
Now the answers to the questions?
Scorke
Scorke
Yup realized and edited
Don't worry 35R setup is being constructed as we speak, I'll have nothing to say about 3076 setups when that happens, other than tell people that they make great tq when not attached to ATP hotsides.
Scorke
Don't worry 35R setup is being constructed as we speak, I'll have nothing to say about 3076 setups when that happens, other than tell people that they make great tq when not attached to ATP hotsides.Scorke
