new GT35R setup for my 2.3...
Also, I don't why you are being secreative about the amount of boost you are tuned on, unless for some reason you don't think the dyno #'s are high enough, but they are after all only numbers so I'm not sure why that would be the case.
People are genually curious, I know I am. Please specify what your boost was on that dyno sheet, and also if you are running something other then straight 93 like meth for example.
Flashed.
You were making posts earlier about wanted to get tuned on E85, your sig says 'cornfed' so that would imply you are running e85 but you just stated above that you are not. thats a little confusing to me atleast since I don't keep up with the forums nearly as much as I used to.
Scorke
see, that wasn't so difficult. why all the shadyness?
23.6 psi, those are some solid numbers for that amount of boost.
If you have a log of the boost curve you should post it up in the big '35r spoolup' thread. There are others with 2.3/35r setups you can compare against.
Scorke
Haha only reason for the shadyness was just fooling around, I like you and many others use this website as a resource and I was just having some fun with deadbeatrec and crcrain..... I have to hook up the RPM connection to my zeitronix but when I get back down to school I shall do that!
Scorke
Scorke
so im thinking AMS VSR or alky injection next. i know alky will yield more power but its also more dangerous. it also needs some custom installs which i dont want to deal with rigth now. if i would be able to get 15whp out of the VSR, i would be happy. so then ill go get Ivey tune it and see what kind of power i have.
btw where were u at waterfest? did u see my thread about it?
https://www.evolutionm.net/forums/sh...d.php?t=284483
yea i know u like to **** with me. i just ignor it nowadays.
Between those two options I'd say alky, go with the fancy aquamist one and never look back.
Scorke
I was at the entrance before everybody arrived and at the exit when everybody was leaving I was just shooting pictures all day I never really looked around inside the gates.
Scorke
Scorke
so where were u shooting pics? in the vendor area? post them up. i have a few on my comp i can post. u have to use imageshack though.
With my 30R on race gas I was making 490 480, with meth on this I would be making close to 600, a little less, I don't ever intend on running meth however.
Remember this was a pump gas tune/dyno.
Scorke
one question, where can i get the meth/alky when i run out?
Scorke
-Paul
Scorke
