new GT35R setup for my 2.3...
Old Apr 5, 2007 | 03:18 PM
scorke's Avatar
More to come..
^ 23 PSI 93 Octane 1000cc Injectors HKS Cams 2.3 Stock ECU IVEY TUNE FTMFW
Scorke
Old Apr 5, 2007 | 03:20 PM
SuPeRNeT's Avatar
nice.. SBR? Should Spool a lil later but hit 2x hard!!!!
Old Apr 5, 2007 | 03:22 PM
Spooldyou's Avatar
I thought you hated SBR?
scorke's Avatar
Yup cast manifold, 35R with the ported shroud cover that works unlike the other ones, or so I hear Tial 44mm gate, HKS 280s, what do you reckon it will put down on pump ?
Scorke
Old Apr 5, 2007 | 03:23 PM
scorke's Avatar
Since when did I hate SBR? I bought almost all of my stroker components through them, I bought this manifold and O2 from them no problems.
Scorke
Old Apr 5, 2007 | 03:24 PM
SuPeRNeT's Avatar
450-500 ish on pump? DJ numbers..
Old Apr 5, 2007 | 03:27 PM
Spooldyou's Avatar
Scorke
I must have been mis informed! well, enjoy it, you should have much to tune i have the same kit on my car, let me know if you need any help with the install.
aanndd it should put down about 450ish, but loaddss more torque than a 2 point slow!
Old Apr 5, 2007 | 03:30 PM
Paul Nelson's Avatar
BAh! 2 point slow pfft
Old Apr 5, 2007 | 03:31 PM
Very nice build! i kinda miss my 35r and my BR cast manifold
Old Apr 5, 2007 | 03:50 PM
Aby@MIL.SPEC's Avatar
can you post some detailed photos of the exh manifold, looking into the collector area?
I have only seen topside pics of that manifold.
i like the way that kit looks!
Old Apr 5, 2007 | 03:56 PM
scorke's Avatar
Grr I literally just put the new gasket in there and locked it down I was trying to test fit it. The collector area is pretty damn smoothe, a little hang up where the two inner runners combine with the outer two.
Unlike most other kits and all other cat ones, the two middle runners do not merge on the manifold side of the merge, they are on the front the radiator side is the best description I can say. It is very equal length compaired to the BR cast manifold, and should never crack, it weighs a ton.
Scorke
Old Apr 5, 2007 | 04:05 PM
fusionchicken's Avatar
one day that turbo will be sitting on my front door steps and i will burst out in tears of joy.
Old Apr 5, 2007 | 05:00 PM
Evo_SpeedKing's Avatar
very nice! time to update your signature...
Old Apr 5, 2007 | 05:09 PM
240Z TwinTurbo's Avatar
Looks good, if I were you I would buy your turbo guy some Jack Daniels
Old Apr 5, 2007 | 05:14 PM
scorke's Avatar
Hehe, the beverages are being worked on, the owner of the turbo isn't 21 so he has to call a favor from the roomates
Thanks for the help figuring out the setup
Scorke
