Turbo kit GT3076R....What size injectors could I run with a ECU FLASH and max power pump and race gas,,,,,,,,,
THANKS,.
THANKS,.
if you plan on topping out with a 3076, 780's should be fine, 880's would be a good choice also, but you might give up some idle characteristics depending on your engine management system. If there's a chance you'll go bigger turbo, 880's or even 1000's, just depends on what your plans are.
This is assuming you have a Walbro at a minimum already.
Yup walbro,,,, THANKS,,,,,,,,
Originally Posted by dubbleugly01
if you plan on topping out with a 3076, 780's should be fine, 880's would be a good choice also, but you might give up some idle characteristics depending on your engine management system. If there's a chance you'll go bigger turbo, 880's or even 1000's, just depends on what your plans are.This is assuming you have a Walbro at a minimum already.
If you're going to run C16, then you'd probably want the 880's. If you're ever planning on running E85, then you may have to go as large as 1600cc.
l8r)
l8r)
i would go with 880's or 1000's
720's are the bare minimun and is really pushing it with 500whp
What brand?? thanks..
Quote:
Originally Posted by ny-quiL
I went with 780's for my 3076
