built 2.0 or 2.3
I rev my stock block to 8k. you can rev a built 2.0 to 10,500 if you have the turbo (42r).
The 30r spools up so quick and fast its insane on the 2.3 motor. He road races so the fast spool up is better. could make alot more power with a bigger turbo, but He and I both like the fast spool up with almost no lagI rev my stocker with cossi cams, valve springs and retainers to 8,000 RPM.
Revving to 10,500 Isn't limited to a 42R since the Procco EVO is doing that in a GT40R. I'm sending my motor to Buschur now to get his stage 3 so I can crank the boost and Rev high!!!
