20gLT vs 3076
From: Work - New York, Alaska, Mexico or the Caribbean. -Home - Tx Hill Country
No, this isn't true. Buschur himself switched to a T3 from his Mitsu housing and gained power, 20 to 30 whp IIRC. You can find it from back in 03 or 04 if you look.
415whp@22psi (93) Stock ecu with a bad boost leak. EMS is ordered and going in and tuned by AMS next month so i'll give the solid numbers then on pump and race gas (~32psi).
I did run a 11.5 with just 26-27psi though. I might run once more with the stock ecu just to get the numbers right since i couldn't go any higher in boost(blowing spark). I'll just change the plugs as soon as i get there!
Edit, yes it was on AMS's dyno
You have the ATP kit right? If so I'm sure the making of less power has to do with the turbine housing.
Im not sure on what you have to convert yet just to run E85, from what i have seen/read you can just dump it in, tune, and go. I've been bugging AMS a little bit b/c they have been doing testing with it for about a month or so. I will probably get a E85 tune if i dont have to replace all the fuel lines. I have a Mobil 5 miles away that charges 2.06/gallon so it would be worth it even though you do burn more fuel
and the less whp is due to a slightly smaller turbo. i just talked to FP and they said the difference is 20-50hp from your to my 3037s. but yes my housing is said to be restrictive but whatever. i ported it and matched the gasket so im not so sure its all that.
also figure u have a 2.3 so more displacement = more power. also u have 1psi more then me, which makes a big difference sometimes when running bigger turbos.
Yea, you really can't go wrong with a big turbo on high octane fuel that only costs $2. I just want to make sure none of my fuel components fail if i run it a lot. How long have you had it in your car? Did you change anything besides the tune?
In the past there were a few different compressor trim options on the HKS GT3037, don' t know if this is still the case. Check their website.
Garrett sells the GT3076R in the largest trim possible (56) since demand for the smaller trim compressors was minimal. The Garrett turbine housings for the GT30R all have a T3 flange. These are the same housing castings as used for the GT35R and they come in 0.63, 0.82, and 1.06 A/R.
and u have to change all the fuel lines and the rubber seals on the injectors to run e85.
Yes i agree 1psi will make a little more power on the big turbo. Good choice on porting the hotside
yeah fp likes doin' this... renaming things with pound per minute rates. i've personally never had a problem with it but it does take a lotta info out of the wheel sizes. that might be the point though as there's always secret squirrel **** goin' on and the other things is people can't even get the garrett stuff straight half the time so it's prolly better to just take the name for what it's worth. of course their proprietary housing makes it necessary to not confuse with garrett line of products.
Not saying that's what FP does, just a general statement. In fact their turbine housing for the "FP30" is quite nice really.
Sorry to ask a newb question, but is the GT35R or GT3082 a good turbo on a IX with cossie cams for use in HPDE events? My final intention is to find a good turbo kit on stock IX block with cossie cams to put some serious hp and tq to help in HPDE events...
I changed nothing but the tune. It takes a bunch more fuel, but it is well worth it. I'll eventually run it at 30 psi daily and see what it feels like.
