shaft play
Old Apr 17, 2007 | 08:31 AM
REDEVO1113's Avatar
shaft play
Is a little shaft play normal on stock, or 20g turbos. I heard that there has to be some to allow a film of oil in through the journal bearing is this true. The reason I ask is because I just bought a 20g evo9 turbo, and it has some shaft play. It doesnt look like the fins are damaged at all, or the housing either. Please let me know if this will be ok. The company I bought from said threy inspected it for shaft play and their was none. I bought it from gruppe s a few months back. They are a pretty repetable company, do you think they might have meant that their is no abnormal shaft play, and not that their is none whatsoever. Please all comments and advice will be greatfully appreciated.
Old Apr 17, 2007 | 08:33 AM
Pure Playaer's Avatar
Excuse my ignorace, because i honestly dont know.. But what IS Shaft Play?
Old Apr 17, 2007 | 08:38 AM
REDEVO1113's Avatar
shaft play is when you can wiggle the turbo shaft slightly in between the compressor housing and turbine housing.
Old Apr 17, 2007 | 08:39 AM
Nez136's Avatar
Basically, When you can move the wheel in the turbo back and forth. Im not sure about the original question though.
Old Apr 17, 2007 | 08:41 AM
red evo8's Avatar
just wiggle the impeller side to side and back and forth , if it doesn't move and just spins it doesn't have any shaft play
Old Apr 17, 2007 | 08:49 AM
REDEVO1113's Avatar
Can anyone answer the question at hand?
Old Apr 17, 2007 | 08:50 AM
cij911's Avatar
Some is fine...I don't know the spec's but if the fins cant touch you're fine IMO...I called FP and asked the same question...
SnailSpeed
Jan 21, 2017 07:39 PM
zbestevors
Apr 28, 2016 10:39 PM
sw20
Sep 20, 2010 06:36 PM
EvoAlex48
Jul 25, 2009 02:56 PM
Motoxrider7
11
Feb 15, 2009 09:45 AM
