Dumb question on UICP
Old Apr 19, 2007 | 06:26 AM
The.alibi's Avatar
Originally Posted by Jdav79
Replacing the pipes with pipes the same diameter and same amount of bends as factory are not going to do anything for you. Shortening the pipes on the other hand will actually give you slightly more power. That's why the companies that are actually pushing big numbers require smaller batteries.
I disagree, the only reason to go with hard pipes is not the fact that the eliminate bends, air actually flows better over the hard surface for one. Another reason is that the stock rubber pipes actually flex under boost. In other words, hard curvy pipes will make power over stock, but not nearly as much as Buschur or others.
Stock < Dejon < Injen < Buschur
Old Apr 19, 2007 | 06:27 AM
recompile's Avatar
Thanks for the feedback!
I will consider a mini battery and Buschur... if not, then Injen may have to do.
Old Apr 19, 2007 | 06:32 AM
The.alibi's Avatar
I think buschur prices may also be less that injen, i had the dejon pipe before i went to the buschur and i love it.
Old Apr 19, 2007 | 06:51 AM
LilRico's Avatar
If I were you I'd get the Injen UICP, which would mount right up to the Deluxe FMIC and you would not have to replace the battery. Now, my recommendation would be to get Buschur's UICP, with the mini battery and get the Deluxe core if you couldn't get the Race care! The Race FMIC is a mod you would install and never have to worry about the intercooler again! Point blank, no matter how stock or how tough you make your EVO, the Race FMIC would be able to handle all mods and you would just be done with it!!
Old Apr 19, 2007 | 07:00 AM
LilRico's Avatar
Don't forget that going to a mini battery, like the one Buschur sells, takes 20lbs off of the car as well!
Old Apr 19, 2007 | 08:54 AM
Bosshog's Avatar
true - another reason I got nisei uicp was to save weight from the small battery to balance out weight gain from an upgraded intercooler.
Old Apr 19, 2007 | 10:56 AM
Jdav79's Avatar
Alibi: You are correct air flows over a smooth surface much better, however have you looked inside the soft IC Pipes, they are extremely smooth. So IMO no difference there.
The fact that harder pipes do not flex are a +1, however that creates very little gain.
Now I do not claim to be an expert, but what I am typing is information that does come from the experts!
DawnoffateX
60
Dec 14, 2008 02:28 PM
evane
Nov 14, 2008 08:58 AM
groove304
40
Oct 31, 2008 11:20 AM
propellerhead
Oct 15, 2004 07:23 PM
caymandiver75
16
Jun 30, 2004 09:43 AM
