??? where is the evo ix suppose to hit the rev limitter???
Old Apr 26, 2007 | 08:53 AM
apagan01's Avatar
attached is the technical specs bulleting from Mitsu and it says redline at 7k,, my Evo ix 2 month old for a fact does not redline at 7k is more like almost 8k
???? where is rev limiter suppose to be stopping the engine,, this is odd ????
Old Apr 26, 2007 | 08:54 AM
nic411's Avatar
i believe it's 7606rpm
Old Apr 26, 2007 | 05:40 PM
apagan01's Avatar
got it thanks anyways,, goobers
MODE 0 (M0) FLASH:
Mode 0 flash will remove all of the standard limiters set by the factory.
Raise Rev limiter (Stock is 7600rpm)
Raise Speed Limiter (Stock is 155 mph)
Remove Boost cut
Remove Boost tapering
Add the Jestutterbox Launch Control - This is a stationary launch limiter that will build boost at the line. For 2005 - 2006 Evolutions, the launch rpm can be moved or deleted.
unihappytime
Jan 9, 2014 04:28 AM
asu11
Jul 23, 2011 01:14 AM
xmaciek82x
39
Feb 12, 2011 09:56 PM
Wayne99gsr
13
Jul 1, 2008 08:38 AM
eag36
20
Oct 12, 2007 02:45 PM
