no lift shift??
i NLS as well when at the track and sometimes on the road when i feel like it, tho i don't do it often. it is a hard habit to break when you're use to lifting for every shift, but once you get it, you'll love it! i NLS on 2-4th gears with a stock trans and on a stock clutch before i switched to an exedy twin disk (still a stock trans) and have had 0 issues.
good luck with the rebuild, and sorry to hear about that
i would re-look at what you're 2 step is set at....seems too low IMO
