AMS High Flow Cat. Pass Smog?
Yup. I use to be a smog tech also. We don't care if it's a HF or not, just as long as you have one. Now if your car fails , then your sh*t out of luck.
Visually, the HFC would fail
Sorry I am no expert in smog testing. Car was tuned by RRE and has no CEL. Are you saying then if the tech doesn't bother to look under the car or knows what the stock cat is supposed to look like, it will likely pass? Thanks!
Yes, if the shop is not hard on the visual you should be OK. You should have your ECU scanned before you go in to ensure all the o2 sensors are logged in. Being that youre tuned, all your sensors may not be "ON"
Where/how can I get my ECU scanned? Do I need to go back to RRE?
Any OBDII scanner can read the o2 readiness. Or call Sam at RRE & ask him to do it. After all the $$$ you spent there, they should provide that service at no cost
You certainly dont want to go to the smog station & have them do that & then fail you
WTB[West]: Need a stock cat
a6mzero
Jan 9, 2018 02:00 PM
