Safe Boost
Old May 16, 2007 | 11:04 AM
kreionic's Avatar
yeah man its all in your tune. I am running 24-24.5 without any issues. Not even a single count of knock here or there. Thats even after being heatsoaked
Old May 16, 2007 | 12:14 PM
hondafan's Avatar
Originally Posted by vmrevo9
so do you have to have head studs to run 23psi daily. keep in mind that i'm not boosting all the time.
you should be fine running that daily on a IX.
Old May 16, 2007 | 12:56 PM
sparky's Avatar
What is the octane number of the gasoline that you will be running? What is the static compression ratio of your engine rebuild?
Old May 16, 2007 | 12:57 PM
sparky's Avatar
Just out of curiosity, why did you rebuild your engine in the first place?
Old May 16, 2007 | 01:24 PM
mudduck's Avatar
as was already said above, it's dependent on your custom tune/tuner...
My IX was tuned to spike to 24psi on pump 93. It depends on how aggressive the tuner is with your timing.
Some guys are boosting like 25psi with their IX's on pump gas, but they are not running as much timing, so really not making any more power than someone running like 23-24psi with more timing.
Old May 16, 2007 | 02:54 PM
Jspec EVO VIII's Avatar
I'm running 25psi w/the mods in my sig. 93octane as well. Jester tuned. Like everyone has stated, really depends on the tuner
Old May 16, 2007 | 10:39 PM
vmrevo9's Avatar
Veteran: Air Force
thanks
Old May 16, 2007 | 10:49 PM
JohnBradley's Avatar
I still have yet to see a stock turbo HG failure that was strictly boost related and NOT detonation related. Are headstuds added insurance? Yes, but are they needed on a stock or Green? Most likely not. As Kreionic pointed out there are plenty of cars that run 24+ psi without knock and are running moderate timing. For reference his car is running 3* at peak torque at that boost level on a stock turbo and on my car with a Green and yet to be finished tune(as per MY requirements for my personal car) I am running the same timing at 24psi. I have been able to run as much as 6* at 25psi on 92 with a stock turbo and no detonation.
Cliffs- 23-24 is fine even with a Green on good pump fuel, and 26+ on 104+ octane and a good tune.
Old May 17, 2007 | 04:03 AM
Evo_7's Avatar
Get a wideband.......
And then tune it accordingly...
Btw you have a good engine built.....
If i wee you i would put in a bigger turbo like a 35 or a 37r...
tsherriff
Nov 9, 2006 03:33 PM
evoeffect
21
Jan 1, 2006 08:49 PM
deadbeatrec
Apr 1, 2005 07:14 AM
